Contacts in a public folder synching with a user's contacts
  • Thread starter Thread starter WordWizard2911
W
WordWizard2911
We want to create a public folder that will house the contacts for a
marketing list. We want the firm to participate by having each person move
contacts to the public folder.
Are sticking points are: What if two people have the same contact how do we
reconcile that?
When we do have just one unique contact for each person in the public
folder, is there a way to synch it back to the original owner's contact so
they stay current? We don't want them to have to update twice.
I think it's better to create a list of all the contacts in excel. Each
employee gets an excelsheet (person name - adresses as example for excel
file name) that you prepared so they just need to push a button to let
excel collect all the adresses of their default adressbook (probably
they get a security warning that excel wants to use info from outlook).
They send you the file and you merge all those files (put them in one
directory ex. charlize - adresses.xls). Then check on full contacts
name, name and surname and streetname and streetnumber after all excel
files are merged (you did use sorting to ease viewing - for a look at a
glance to see that you need to refine stuff).
Just and idea off course.
Charlize
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
S Contacts disappear in public folder search Using Outlook 1
G Outlook 2013 - Default View for Public Folder Contacts Using Outlook 1
C [outlook-users] Public Contact Folder not Listed under contacts tab Using Outlook 3
K Master Category List / Contacts Public Folder Advice Using Outlook 4
A New Contact entry (custom form) get saved in a public folder and doesn't appear in Outolook Contacts Outlook VBA and Custom Forms 3
P Copy Contacts in a Public Folder to a Local Contacts Subfolder Outlook VBA and Custom Forms 6
T managing contacts in public folders Using Outlook 4
A Are Public Folders Contacts available through activesync for Windows Phone 7, Iphone, etc? Exchange Server Administration 3
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
