Sharepoint and BCM
  • Thread starter Jackie LaFollette
  • Start date
Jackie LaFollette
I couldn't access this link. I'd like to learn more about how to integrate Sharepoint and BCM. Thx.
DocMa wrote:
Integrated SharePoint with Business Contact Manager
08-Feb-08
We have integrated Business Contact Manager (BCM) with SharePoint so that BCM
users can access all account, contact records from a document ribbon in the
BCM UI. They can aslo scan documents directly from BCM.
check it out at www.linmar.com/sharepointdm.html
Regards,
The Doc Man
Previous Posts In This Thread:
On Friday, February 08, 2008 11:01 AM
Regards,
The Doc Man
BizTalk Repeating Structures Table Looping and Table Extract
http://www.eggheadcafe.com/tutorial...0-a5704fe31a76/biztalk-repeating-structu.aspx
Raul Thomas
Business Contact Manager stores data in SQL Database; you have a couple of
tools to choose from:
Create a Data View web part in SharePoint Designer, this allows you to
display information from a SQL database, but has the ability to also update,
add and delete records in the SQL database:
Add a data base as a data source:
http://office.microsoft.com/en-us/sharepointdesigner/HA101009081033.aspx
Create a data view:
http://office.microsoft.com/en-us/sharepointdesigner/HA100948041033.aspx
Or SharePoint BDC : this allows you to display information from a SQL
database.
http://msdn.microsoft.com/en-us/library/ms563661.aspx
Regards
Rahul Thomas
MSFT
"Jackie LaFollette" wrote in message
news:20104201335jlafollette@chasemedical.com...
> 08-Feb-08
> BCM
> the
> > Regards,
> The Doc Man
> BCM
> the
> > Regards,
> The Doc Man
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
Diane Poremsky Goodbye, SharePoint Social Connector Using Outlook 0
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
M Map Outlook user defined fields onto a Sharepoint list ??? Outlook VBA and Custom Forms 1
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
F Sync Sharepoint Calendar With Personal Calendar Outlook VBA and Custom Forms 5
Marcy Outlook and SharePoint 2013 - Syncing Contacts Using Outlook 2
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
Stefanos Update Sharepoint tasks through Outlook Using Outlook 2
P Task not visible in SharePoint Using Outlook 5
P Task in SharePoint-list not visible to colleagues Using Outlook 1
M Import distribution list into MS Exchange Sharepoint Exchange Server Administration 3
P Using BCM2010 Business Projects as SharePoint 2007 Data Source BCM (Business Contact Manager) 3
S Display SharePoint document library in a customized Outlook form Outlook VBA and Custom Forms 1
A Replace olFolderContacts for Sharepoint lists in Outlook Outlook VBA and Custom Forms 5
