Problems with code
  • Thread starter Thread starter Gustavo Strabeli
G
Gustavo Strabeli
Hello!
I'm using below code in order to have Outlook adding email addresses to my
contacts folder.
So here's the problem: adresses are being added to my contacts however it's
inserting quotes before and after the address.
I don't know nothing about VBA, but analysing the code I deleted the Chr(34)
from the code and this problem was solved, however another problem
was raised: now all my contacts are being duplicated.
Do you know how to fix that? I mean, delete the quotes and don't have the
contacts duplicated?
Thanks a lot,
Gustavo
The code:
Sub AddRecipToContacts(objMail As Outlook.MailItem)
Dim strFind As String
Dim strAddress As String
Dim colContacts As Outlook.Items
Dim objContact As Outlook.ContactItem
Dim objRecip As Outlook.Recipient
Dim i As Integer
' get Contacts folder and its Items collection
Set colContacts = _
objNS.GetDefaultFolder(olFolderContacts).Items
' process message recipients
For Each objRecip In objMail.Recipients
' check to see if the recip is already in Contacts
strAddress = AddQuote(objRecip.Address)
For i = 1 To 3
strFind = "[Email" & i & "Address] = " & _
strAddress
Set objContact = colContacts.Find(strFind)
If Not objContact Is Nothing Then
Exit For
' if not, add it
If objContact Is Nothing Then
Set objContact = _
Application.CreateItem(olContactItem)
With objContact
> FullName = objRecip.Name
> Email1Address = strAddress
> Save
Set objContact = Nothing
Set objNS = Nothing
Set colContacts = Nothing
Function AddQuote(MyText) As String
AddQuote = Chr(34) & MyText & Chr(34)
End Function
I assume you have a lot of contacts already stored with quotes. Delete all
those contacts and run your code again. Then you should end up only with
addresses without quotes.
Best regards
Michael Bauer
Am Wed, 27 May 2009 11:03:45 -0300 schrieb Gustavo Strabeli:
> Hello!
> contacts folder.
it's
Chr(34)
> Thanks a lot,
> Gustavo
> The code:
> Dim objNS As Outlook.NameSpace
> Dim i As Integer
> On Error Resume Next
> Set objNS = Application.GetNamespace("MAPI")
> Set colContacts = _
> For i = 1 To 3
> strAddress
> Exit For
> End If
> Next
> ' if not, add it
> Set objContact = _
> With objContact
> .FullName = objRecip.Name
> .Email1Address = strAddress
> .Save
> End With
> End If
> Next
> Set objNS = Nothing
> End Sub
> End Function
K Outlook for Mac problems Using Outlook 0
