Entering Contacts at Same Company
Johnster
With MO 2010, how do I enter a new contact at a company for which I already have a stored contact without having to re-enter the company information again. I used to be able to make a duplicate card and then just edit the name field, however, I can no longer find that option. Thanks.
L Entering dates in Contacts and Calendar Using Outlook 4
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
W Go to search field when entering a contact folder? Using Outlook 2
Z Syntax for entering same statement as a reply Outlook VBA and Custom Forms 2
L new outlook contacts searching Using Outlook 2
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
