Office Profession Plus 2010 is not working for custom forms
Gunasekar
We have migrated from Outlook 2007 to 2010.
We had a large number of organizal template forms to be send out for customers and it was working very good in outlook 2007, but after we migrated to outlook 2010 the template is not working as earlier.
We are able open the template and edit the content but the email sent to the recipients is not having the edited content and has only the template content.
I have created a local user template form the content and used to send it to myself and got the same with no image and 2 attachement as blocked content. (Not able to open the attachment as well, if i do it shows me the internet exploere tempororay files folder and in editplus not readable format)
Please help me to fix this issue.
Do they contain scripts? If so, go to File, Options, Trust center, email security - are you allowing scripts?
Did you increment the version number when you republished the templates? If you don't, frmscache can be come corrupt.
Thanks for your response.
I do have both options. but no luck.
However when i change the email format to rtf after loaded the template, the changes i edited is being to the recipient.
I have read some forums below
Outlook 2010 - Sending HTML base oft Files is converted to RTF - Microsoft Community
and the corresponding hot fix Description of the Outlook 2010 hotfix package (x86 Outlook-x-none.msp; x64 Outlook-x-none.msp): August 30, 2011
Is it possible for you to confirm the above fix works for me?
Thanks, i greatly appreciate your effort and time
Yes, that hotfix does work - and it should be in a later update. If the hotfix won't install and gives you an error about expected versions not found, it's already installed.
Whether it will fix your problem, I'm not 100% sure.
C Which version of Office? Using Outlook 4
P newly installed Office 365 includes OLD Outlook Using Outlook 6
Y Q's Regarding Office 2019 Using Outlook 0
S Import PST to Office 365 Using Outlook 1
C Migrate Exchange to Office 365 Using Outlook 2
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
U Rolling Back Office broke automatic updates Using Outlook 4
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
S Outlook 2021 How to customize colors Outlook 2021 & Office 2021 on PC Using Outlook 1
O Office 365 - Zoom Using Outlook 0
C Wishlist Extract or scan new email addresses from out of office replies. Leads from OOO replies Using Outlook 1
M Upgrading from: MS Office Professional Plus 2010 to: MS Office Professional Plus 2021 Using Outlook.com accounts in Outlook 16
D Office 365 Outlook desktop app prompts for all account passwords on startup Using Outlook 11
V Outlook 2021 Microsoft Office Pro Plus 2021 - Inexpensive Lifetime License Using Outlook 6
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
klpconsulting Programmatic Access Office 365 Pro Plus & RDS Using Outlook 1
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S office 2016 pop3 Using Outlook.com accounts in Outlook 3
Albert McCann Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
