Color
Thanks. Can you please explain where and how to do that? As I am not aware of what this is and how to do it.
In Forms Designer, switch to the properties tab - its the next to the last one on the right. enter a number in the versions field - 1.01 or whatever you want. Then publish. Raise the # every time you publish a new version of the form.
Thanks again. But the important question is as follows:
Under each Outlook contact folder (which I have many many of), I had to right click each folder, go to properties, and pick my new form as the form for the folder. I have not had to do that each time i update the form and publish to the same name.
If I add these versions field, will I need update each folder of my contacts to the newest version number somehow?
And I am not clear where the name Form Designer is and the properties tab.
As long as the form name is the same, changing the version # will only cause the outlook to update the items to the new form, you won't have to select the form on the folder properties dialog.
forms designer is when you are using Design this form. :)
Thamks. It shows two areas: Version and Form Number. So what for each area??
Once again, I did everything you told me and it works perfectly! And the form of contacts is in perfect shape now!!
I just posted another important question just in case there is a way to do it.
Thanks so much for your support!!
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
M Emails sorted by conversation including replies and categorized by color. Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
C Color Code New Calendar Items Using Outlook 2
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E Outlook 2016 Default Blue Color Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
J Color Alignment on the Calendar? Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
B Sub Calendar-Color Coding Issue Using Outlook 4
D Calendar - color coded items are now the same color Using Outlook 2
B Color Categorizing 365 Using Outlook 8
J Change Default View - Color and font Using Outlook 3
Tom.Schaefer Color for Mail-folder in OL2013 Using Outlook 1
K Color Categories for Accounts and Contacts BCM (Business Contact Manager) 0
M Background Color? Using Outlook 1
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
D Background color for an entire day in Outlook 2010 Using Outlook 1
Commodore Color options in 2010... Using Outlook 0
U Color coded contacts Using Outlook 4
T Setting Color codes for each user of a shared Calendar Using Outlook 1
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
M Assigning a specific font color to new emails using rules when they arrive Using Outlook 3
L Background Color Is An Issue Using Outlook 3
J Color categories with shared mailbox Using Outlook 1
F Color Coding Emails - Outlook 2007 SP-3 Using Outlook 1
C Apply Category Color for Appointment Background Color Using Outlook 2
N Changing background color on replies and forwards Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
M How do you change the obnoxious color of the email headers on Outlook 2013? Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
J Text color when creating a new Task is not consistent Using Outlook 1
S Color catagories Using Outlook 1
