Task not visible in SharePoint
pabe1250
Hi!
The code below converts incoming mail in Outlook to a task and moves the task to a SharePoint-list. So far so good:)
When the task appears in the SharePoint-list it should be given a status (Not Started, Started, Completed) automatically. This is a requirement to make the line visible when connecting to the SharePoint-list through a browser.
My problem seems to be that the task is moved into the SharePoint-list without any status what so ever, thus not visible. The solution is to manually click on "Tasks" in Outlook and then return by clicking the SharePoint-list in Outlook. Then the task changes from no status at all to "Not Started".
Is there any way to have the task set to "Not Started" as default behaviour automatically - perhaps by adding some code to the macro?
Sub ConvertMailtoTask(Item As Outlook.MailItem)
Dim objTask As Outlook.TaskItem
Set objTask = Application.CreateItem(olTaskItem)
'move this up here just to get it out of the way
Set SPSFolder = GetFolderPath("SharePoint-lists\Any_given_folder")
' this creates and saves the task
With objTask
.Subject = Item.Subject
.StartDate = Item.ReceivedTime
.Body = Item.Body
.Save
' this can go right before 'end with' (if so remove ojbtask from it)
objTask.Move SPSFolder
' this goes last, before the sub ends
Set objTask = Nothing
Function GetFolderPath(ByVal FolderPath As String) As Outlook.Folder
Dim oFolder As Outlook.Folder
Dim FoldersArray As Variant
Dim i As Integer
On Error GoTo GetFolderPath_Error
If Left(FolderPath, 2) = "\\" Then
FolderPath = Right(FolderPath, Len(FolderPath) - 2)
'Convert folderpath to array
FoldersArray = Split(FolderPath, "\")
Set oFolder = Application.Session.Folders.Item(FoldersArray(0))
If Not oFolder Is Nothing Then
For i = 1 To UBound(FoldersArray, 1)
Dim SubFolders As Outlook.Folders
Set SubFolders = oFolder.Folders
Set oFolder = SubFolders.Item(FoldersArray(i))
If oFolder Is Nothing Then
Set GetFolderPath = Nothing
'Return the oFolder
Set GetFolderPath = oFolder
Exit Function
GetFolderPath_Error:
Exit Function
End Function
I think I am getting closer now. Please look in to this code:
Dim strStatus, strPriority
'other task defaults
strStatus = 0
strPriority = 1
With objTask
.Status = strStatus
.Importance = strPriority
.Body = Item.Body
.Save
Shouldn't these adjustments make the task set to status "Not started" and "Normal" and thus become visible?
Well, it's not:(
Any ideas?
/Paul
SharePoint tasks use a custom status & custom priority field and i assume that is why its not working. Add the status and priority fields to the view, along with the 2 custom fields and see if the values are synced.
you lost me there....
I assume your idea means that the custom status and custom priority fields should be integrated in the current macro. But how? I'm really on a beginner's level when it comes to this.
"Add the status and priority fields to the view"....?.....they are already visible both in Outlook and SharePoint....but when the macro has executed their values seem to be NULL/unset.
When I manually click the task directory then both values are set. That means that by doing so the "Status" from Outlook becomes a "Custom status" in SharePoint.
Do you mean I should put the custom fields in the code above? Using strCustomStatus and strCustomPriority - or?
You're discussing something about it here; http://www.slipstick.com/outlook/tasks/custom-priority-field/
Is this sufficient to make it work or does it need some more coding?
in looking with outlookspy, these are the property accessors -
http://schemas.microsoft.com/mapi/id/{00062003-0000-0000-C000-000000000046}/8137001F
http://schemas.microsoft.com/mapi/id/{00062003-0000-0000-C000-000000000046}/8138001F
These two should point you in the right direction on how to use them - MSDN shows how to read and write:
MSDN: http://msdn.microsoft.com/en-us/library/office/bb176395(v=office.12).aspx
OutlookCode: http://www.outlookcode.com/threads.aspx?forumid=4&messageid=27801
Well, I'm sorry:(
I tried the code upside and down without getting any compilation errors, but still the status/priority don't get pasted into the custom status/priority, thus remains invisible in SharePoint.
Thanks for your effort.
/Paul
P Task in SharePoint-list not visible to colleagues Using Outlook 1
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
K Daily Task List Minimized Cannot Display Using Outlook 5
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
K Multiple copies of task being created Using Outlook 2
P Short Date Format when typing in a task Using Outlook 2
C Outlook 2013 Task Recurrence - Third Friday After the Second Tuesday Using Outlook 2
P Task display now leaves little room for notes Using Outlook 10
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
D How To Combine Share Task Folders in just one Folder Using Outlook 0
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
P Can't paste an image into a task Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
T Report For Task Recurrance Outlook VBA and Custom Forms 4
E Can't accept or decline task (no button appears) Using Outlook 2
X If you change expiration date of repeated task it dupplicates Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
Z VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
M Daily Task List Minimized Cannot Display Using Outlook 2
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
W Deleting Sent Task Email, Deletes the task from my list Using Outlook 1
K Task priority modification Using Outlook 4
F Search folder for tasks in all task folders Using Outlook 1
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
F How to assign a task to a public task folder? Using Outlook 1
copperberry How to view all tasks across task folders Using Outlook 3
P Task Categories Using Outlook 2
