Forwarding and keeping Original intact
I’m trying to manage e-mails while on a trip. The two computers have Outlook 2003. When I use a rule to forward a message (I don’t use an Exchange Server) Outlook marks the original message as Read automatically and I can’t find any way to avoid or reverse that. It becomes an issue when I return and have to act on messages that came while I was out, and if they seem Read I pass them by.
I found that if I create a rule to move a copy of the incoming e-mail (from one particular account (rome74@outlook.com)) to another folder (called “Hold”) I can keep the original in the un-Read state. Well, that seemed handy, but I ran into the next problem.
How do I run an automatic process on the e-mails in Hold? There doesn’t seem to be a way to target a sub-folder for an action, just the Inbox.
What I would like to do is, once the e-mail copies meeting my first rule have been placed in Hold, run an action on the those copies to forward them to another e-mail address (rm54321@outlook.com) and then somehow prevent that action from repeating itself on previously forwarded messages, like deleting the copy once it’s forwarded. That would forward the messages, and keep the originals Un-Read.
I only need it to work in the Hold folder: check for new messages placed in the folder, forward those messages, and delete once forwarded.
Is this possible?
I’ve been looking at the VB scripts and macros on Slipstick.com and several have parts of what I need, but I’m so programming-challenged (read overwhelmed by it) that it all looks like a foreign language and I don’t know how to pull the various parts together.
Can you help?
Ronda
Rules only run automatically on the inbox. If you are managing the mail in outlook (not in the outlook.com interface) you can use vba to forward. If the only need is to forward the mail and leave it unread, a macro can do that - i might have one ready to use. That would simplify your setup.
The macro here http://www.slipstick.com/outlook/rules/run-script-rule-change-subject-message/ works off a rule. Remove the lines that change the subject and save it, and if it marks mail read, you can use
Item.unread = true
Item.Save
before end sub
if you want to use your current setup, you can use an itemadd macro to watch the Hold folder and do something as messages arrive.
The macro here http://www.slipstick.com/developer/code-samples/process-items-shared-mailbox/ has the basics.
if Hold is under Inbox, change this line
Set olInboxItems = GetFolderPath("Mailbox name in folder list\Inbox").Items
to
Set olInboxItems = Session.GetDefaultFolder(olFolderInbox).Folders("Hold").Items
When I type in the Message area the font size is HUGE, even though it says it is only a 12 point font. When it does get received by the recipient, what I have typed in the Message area does print out in 12 point font. However, how can I make what I type in the Message area to reflect a 12 point font?
F Outlook 2019 Forwarding Message and Keeping Unread Status Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
T Original email text not shown when replying or forwarding the email. Using Outlook 9
A Automatic forwarding to different people on a rotational basis Using Outlook 2
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
A Forwarding email and replacing body Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
W Forwarding E-Mail Outlook VBA and Custom Forms 13
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
N Auto-forwarding an Email received from a specific Email address After slight modifications Using Outlook 4
J Creating a URL from a message body excerpt before forwarding Using Outlook 2
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
E Contact's Notes field not transferring when forwarding vCard Using Outlook 6
J Meeting Invites Go Blank When Forwarding or Accepting Using Outlook 2
D Forwarding Exchange Email without meeting updates Using Outlook 1
A Emails automatically forwarding but no rule to turn off Using Outlook 2
T Adding text to forwarding rules in Outlook 2010 Using Outlook 1
T Adding tex to forwarding rules in Outlook 2010 Exchange Server Administration 1
L Forwarding an expiring message Using Outlook 0
T To: and Cc: not displaying when forwarding/replying to .eml files Using Outlook 4
V Reply Arrow Icon appears when both Replying or Forwarding Using Outlook 3
C forwarding from 365 to hotmail account? Using Outlook 1
F VB Script, remove text from subject line when forwarding Using Outlook 22
C Forwarding Outlook 2003 calendar items Using Outlook 1
B Outlook 2003 randomly not auto forwarding Using Outlook 0
M Forwarding vCard prompts Send As (From field) on Contacts that were moved Using Outlook 6
B OL2010 - signatures while forwarding tasks or appointments Using Outlook 2
D Private messages not forwarding by rule? Outlook 2007 Using Outlook 1
T [outlook-users] e masil forwarding Using Outlook 2
A Font size increases when forwarding emails Using Outlook 1
A Forwarding recurring appointment/meeting Using Outlook 2
P Forwarding Email With Encrypted Attachment Exchange Server Administration 1
A How do I move a message to a folder after forwarding ? Outlook VBA and Custom Forms 6
V Remove old recipients before forwarding Outlook VBA and Custom Forms 1
A How to change message format while forwarding a mail Outlook VBA and Custom Forms 1
V Re: Email Forwarding Outlook VBA and Custom Forms 1
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
Commodore Keeping two computers in sync Using Outlook 5
S Copying multiple messages to folders and keeping date/time detail Using Outlook 1
