Outlook 365 synchronisieren
Outlook 365 stephan
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    Windows 64 Bit
Outlook version:     Business Premium 365
Email type or host:    IMAP
Hallo Slipstick Forum,
aktuell kann ich in meinem Outlook Classic die E-Mails nicht mehr vollständig abrufen, weil das System von "Übermittlung/Senden/Empfangen" auf „synchronisieren“ umspringt und dann ist der PC nicht mehr per Maustaste navigierbar und ich kann nur mehr „Programm schließen“ oder „Neustart“ anklicken.. . Laut meinem T/Magenta-Provider sind die IMAP Konten korrekt.. Laut Microsoft Support soll ich auf Outlook Neu umsteigen, da das Problem bei Outlook classic nicht behoben werden kann...
Bitte um Rückmeldung ## Systemcode Fehlermeldung 800 4DF03 00 560
stephan 1040 Wien
currently I can no longer retrieve the e-mails completely in my Outlook Classic because the system switches from "Transmission/Send/Receive" to "Synchronize" and then the PC can no longer be navigated by mouse button and I can only click "Close program" or "Restart". . According to my T/Magenta provider, the IMAP accounts are correct. According to Microsoft Support, I should switch to Outlook New, because the problem cannot be fixed with Outlook classic...
Please feedback ## System code error message 800 4DF03 00 560
stephan 1040 Vienna
It may or may not be fixed in classic - but new Outlook isn't necessarily the answer, depending on how you work.
Do you have any sync issues? Look in the Sync issues folder in the Folder navigation pane.
Use Ctrl+6 to open the Folder list pane if the buttons are on the bottom. If your Outlook navigation buttons are in a vertical bar on the left, click the bottom icon in the vertical bar and choose Folder. To switch back to the Mail pane, click the Mail button or use the keyboard shortcut Ctrl+1.
Errors will be in red text in the Sync Issues folder. If you have a few a day it's not an issue, but a large number could mean problems.
Some errors are meaningless. Things like message count not the same online and in count. This happens when you delete a message and is fixed on the next sync. Or a sync error when you close outlook. They can be ignored.
Right click on the folder and Empty it to clear the entries after reviewing the newest ones.
Das kann in Classic behoben werden oder auch nicht - aber neues Outlook ist nicht unbedingt die Lösung, je nachdem, wie Sie arbeiten.
Haben Sie Synchronisierungsprobleme? Schauen Sie im Ordner-Navigationsbereich in den Ordner „Synchronisierungsprobleme“.
Verwenden Sie Strg+6, um das Ordnerlistenfenster zu öffnen, wenn sich die Schaltflächen am unteren Rand befinden. Wenn sich die Outlook-Navigationsschaltflächen in einer vertikalen Leiste auf der linken Seite befinden, klicken Sie auf das untere Symbol in der vertikalen Leiste und wählen Sie Ordner. Um wieder zum E-Mail-Fenster zu wechseln, klicken Sie auf die Schaltfläche E-Mail oder verwenden Sie die Tastenkombination Strg+1.
Fehler werden im Ordner Sync-Probleme in roter Schrift angezeigt. Wenn Sie nur ein paar pro Tag haben, ist das kein Problem, aber eine große Anzahl könnte auf Probleme hindeuten.
Einige Fehler sind bedeutungslos. Zum Beispiel ist die Anzahl der Nachrichten online und in der Datenbank nicht identisch. Das passiert, wenn Sie eine Nachricht löschen, und wird bei der nächsten Synchronisierung behoben. Oder ein Synchronisierungsfehler, wenn Sie Outlook schließen. Sie können ignoriert werden.
Klicken Sie mit der rechten Maustaste auf den Ordner und leeren Sie ihn, um die Einträge zu löschen, nachdem Sie die neuesten Einträge überprüft haben.
Übersetzt mit DeepL.com (kostenlose Version)
Rupert Dragwater Outlook 365 taking too long to synchronize each time email is being checked Using Outlook 12
P newly installed Office 365 includes OLD Outlook Using Outlook 6
C Outlook classic via 365 Using Outlook 2
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
HarvMan Outlook 365 Inbox Font Using Outlook 8
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
M Start Outlook 365 at unified inbox Using Outlook 2
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
J Outlook 365 html inline images Using Outlook 0
Rupert Dragwater How to get Outlook 365 to open from websites Using Outlook 5
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
L Synch Outlook 365 calendar with iPhone Using Outlook 0
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
L Duplicate calendar entries in Outlook 365 Using Outlook 3
G Stop Outlook 365 adding meetings to calendar Using Outlook 1
CWM330 Is it me, or is Outlook 365 BUGGY? Using Outlook 3
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
D Office 365 Outlook desktop app prompts for all account passwords on startup Using Outlook 11
L Recommendations for Utility to Backup Outlook 365 Account Settings Using Outlook 2
Z New minimum Outlook for Windows version requirements for Microsoft 365/Exchange Online Using Outlook.com accounts in Outlook 27
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Outlook 365 refuses to send email Using Outlook 0
P How can I stop Outlook 365 duplicating the posts? Using Outlook 1
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 12
S Mac Outlook 365 Questions Using Outlook 1
R Outlook 365 update sets delete from server flag Using Outlook 1
