Problems with moving msg files to network folder
AH3
Has anyone had problems with Windows 7, Outlook 2010, and Exchange 2010 trying to "move" *.msg files from Inbox to network storage? Move(Copy) or Copy, it only copies messages instead of moving them, so after I "copy" it to network storage, I then have to go back into the Inbox and delete it. This used to work correctly using XP and Outlook 2007. I'm thinking that good ole' Microshaft changed something in Windows 7... Any idea's?
AH
AH3
Hey Diane,
Is there something that I can actually change in the registry to get "move" to actually move *.msg files again, so that I don't have to "move" the *.msg files to a network storage location and then go back and delete them out of my inbox?...
K Outlook for Mac problems Using Outlook 0
