Issues syncing with MS Outlook 2007 with 2 profiles
steve_k1
I have MS outlook with 2 profiles. One uses pop3 for my verizon account. the other uses exchange settings for work email. It was working fine when syncing, i was getting all contacts, appointments from both synced to my iphone 4s with latest ios from at&t. I recently synced it wired when traveling and lost all my contacts, calendar and notes from my verizon pop 3 account on the phone.
I spent hours on with apple support yesterday, they had me unindtall itunes and all apple softweare and reinstall, with no luck.
i installed icloud and that didnt help either.
Any suggestions to get both accounts to sync to iphone. Its defaulting to my exchange data now, none of my pop3 data is getting on the phone.
Appreciate any help from the experts on here :)
Were you syncing directly with the exchange account over the air (using Exchange Active sync)?
Did they have you remove the sync partnership?
Is the exchange profile set as default? You need to set the other profile as default.
VCC Icloud/Outlook Syncing Issues Using Outlook 1
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
S New Outlook - IMAP ISSUES and support for addins? Using Outlook 1
M Issues with templates - unable to find in old web app Using Outlook 3
Commodore iTunes sync on a new computer - any issues to be expected? Using Outlook 9
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
E Imported Contact Issues Using Outlook 11
D Event ID issues Exchange Server Administration 2
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
O Outlook 2016 contact issues Using Outlook 2
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
Kris Petorv Calendar issues Using Outlook 0
Diane Poremsky Internet Mail Issues with Outlook Using Outlook 0
Diane Poremsky Mail Issues with Outlook Using Outlook 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
J Issues in Canceling iCloud Configuration and Reverting to Local PST Configuration Using Outlook 0
Commodore Two Sync Issues folders Using Outlook 4
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
P Outlook 2013 and IMAP: Two popular issues Using Outlook 3
S send/receive issues outlook 2013 Using Outlook 4
P Folder issues using Gmail with Office 2013 Using Outlook 3
L Group Inbox Send As/Send on Behalf Issues Using Outlook 3
Christopher M ( CMAR606 ) Outlook 2010 IMAP issues Using Outlook 2
mwh1962 Sync issues with Windows 8.1 phone Using Outlook 2
M Outlook 2007 IMAP Account Rules Issues Using Outlook 3
J Outlook 2013 and outlook.com issues when using mail alias Using Outlook.com accounts in Outlook 2
mikecox Multiple unexplainable issues Using Outlook 1
G Issues with accessing Outlook Contact Picture with VBA Outlook VBA and Custom Forms 4
J Office 365 small business/Outlook 2013 issues Using Outlook.com accounts in Outlook 1
L Issues with Outlook - errors detected in file Using Outlook 1
D Sync issues Using Outlook 1
R Outlook 2013 IMAP Sync Issues Using Outlook 1
W Outlook 2010 Task bar issues. Using Outlook 8
P Outlook 2010 2 Accounts - Issues Using Outlook 0
V Outlook 2013 - iCloud add-in creates issues Using Outlook 4
