issue/ base and user defined contact types
tlassner
Outlook 2013 32 bit
we just rolled out the BCM in our company.
- database runs on our MS SQL Server 2088 R2, exchange 2010
- 10 Clients with remote access to the BCM database
- all clients run with optional offline sync when offline
- ~ 2.700 business contacts
- ~ 450 account contacts
- base type account is split in two related contact types: customer and vendor/ supplier
Problem:
on two client machines only the base type account is shown, no customers and vendors.
on the other clients everything works fine, except the known issues like wrong label captions (weird label behaviour), ...
thanks for every hint
regards from Berlin
Tobias
I found a solution but did not for the cause of the issue:
- i migrated the productive database to our test db instance, save and restore cause the migration does not work in our case (BCM db tool can't find a db to migrate)
- after it I migrated it the other way around
--> the children contact types are now well shown on the two clients
Perhaps something with the permissions, but I did not find any differences in permission configuration of the MS SQL Server Management Studio
That is odd behavior - it's hard to say what caused it. As for the labels, I have no idea when it will be fixed. It's on te top issues list, but that doesn't give us a time frame for a fix, only that they know its a problem.
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
A Autocomplete issue Using Outlook 6
wallisellener Synch issue BCM (Business Contact Manager) 2
H Outlook 2013 size issue Using Outlook 1
C Voting Issue with Shared Inbox Using Outlook 1
J Outlook 2013 Forms Issue Using Outlook 1
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
J Outlook.com EAS Issue Using Outlook.com accounts in Outlook 6
