Calendar view when working past midnight
jgehman
Living in Mauritius for the next four months, but working US hours, which means I go to work at 5pm and end at 2am. My Outlook calendar won't let me show a range from 5pm to 2am...all my appointments are either at the very top or the very bottom, and I can't see the top while looking at the bottom, and vice versa. I need to either 1) set it to allow a view from 5pm to 2am, or 2) hide the hours from 3am to 4pm so that I can see all my work hours on one screen.
I have a possible solution. I created an appointment starting at the start of my shift. I then opened the Recurrence options window. I entered the start time, skipped the end time, and entered my shift's duration (Start= 6:00 PM; End= 6:30 PM; Duration: 8 hours). After entered the duration, the End changed to 2:00 AM (this trick will not work if you manually enter an end time after midnight). My Reoccurence pattern is set to Weekly, Recur 1 week on: Monday, Tuesday, Wednesday, Thursday, Friday. My Range of recurrence is set to the first day of my tour, and the End by as the end date of my tour. When I clicked the OK button I got a pop-up asking me if it was ok for it to go past midnight; I responed YES. My appointments all start at 6:00 PM and end at 2:00 AM the next date. I then finished it up by clicking back on the appointment and changing the Show as to Free and Reminder to none. I can still create Busy appointments over-top of this Free appointment. For my off days, I just delete those single occurences. We have an internal company application that reads these appointments and changes its status to match this appointment's status of Free.
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
K Accentuating today in Outlook calendar month view Using Outlook 2
P How can I change my calendar view back Using Outlook 3
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Change the displayed fields in calendar view Using Outlook 1
Diane Poremsky How to View a Shared Calendar on a Smartphone Using Outlook 0
V View calendar on backed up Outlook file Using Outlook 6
A Calendar List View Showing Week Number Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
J Other user's calendar view showing as busy in 2007 & 2013 from my account Using Outlook 1
P Is there any way of sorting the task list in CALENDAR view? Using Outlook 4
J Calendar view for future events only? Using Outlook 3
G Calendar monthly view - Print just 3 weeks Using Outlook 5
F iCloud calendar invisible only in Calendar View Using Outlook 2
Britonius Admin cannot view full room calendar permissions Using Outlook 8
V Lost calendar view, items still in list view Using Outlook 2
N Calendar Permissions - Delegates - View Title Only Using Outlook 2
S Displaying the Remind Beforehand Value in Calendar List View Using Outlook 2
S Calendar View Templates? Using Outlook 0
E Adding Start and End Time to Daily View in Calendar Printing assistant Using Outlook 1
O Calendar list view in Outlook 2010? Using Outlook 3
J Print next 7 days view of calendar (2010) Using Outlook 3
R printing custom number of calendar days in weekly view format Using Outlook 1
P Setting Calendar View to Day/Week or Month Using Outlook 2
E Calendar View - Go to Today (Alt+O keystroke gone in 2010) Using Outlook 2
D Outlook 2010 - Calendar - always show 4 weeks in month view Using Outlook 3
G how to change default calendar view to show this week and future weeks? Using Outlook 1
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
M Outlook Calendar Monthly View Missing Appointments Using Outlook 3
R OL 2010 default calendar view Using Outlook 6
G How to NOT display the start time in monthly calendar view - 2007 Using Outlook 8
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
T Using Exchange, the calendar cannot be synchronized. Using Outlook 3
B Sync Google Calendar with Outlook Using Outlook 5
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
