OL 2010 default calendar view
my OL 2010 just started defaulting to "Day View" instead of the LAST view that was visible prior to exiting which is ALWAYS Month View. I've tried disabling all add-ins to no avail. Reboot didn't help either.
larry
Set the view you want and close outlook. The view should stick when you reopen as long as outlook closes correctly.
After you close outlook go to Task manager, processes tab and verify Outlook is closed. When views don't stick one cause is outlook not closing cleanly.
what addins do you have installed? What antivirus do you use? Those could be causing problems. (Testing in Safe mode wont work for this as the view shouldn't be saved in safe mode.)
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
L Outlook 2010 Default Calendar Using Outlook 2
ogodt Change Default contact form and import from Excel 2010 Using Outlook 1
J Outlook 2010 Email Not Default Email Using Outlook 1
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
T Make Default Outlook 2010 Client Mail Using Outlook 1
S How to set Company as default "File As" in Contacts for Outlook 2010 ? Using Outlook 1
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
G set exch 2010 server as the default hub transport Exchange Server Administration 6
S change default contact list in Outlook 2010 to "contacts" rather than "global" Exchange Server Administration 1
C Outlook 2010 - Default PST location Using Outlook 4
B MS Office 2010: Word email merge not selecting default Outlook account Using Outlook 1
J Move PST /changing default location in Outlook 2007 or 2010 64b on W7 64bit Using Outlook 2
N Default IMAP account not working after SP1 for Outlook 2010 installed Using Outlook 6
J How To Change Default View of Tabs in Outlook 2010 Using Outlook 4
F Outlook 2010 - Default font color keeps changing frim the one I set. Using Outlook 1
D Outlook 2010 default font Using Outlook 9
M Upgrading from: MS Office Professional Plus 2010 to: MS Office Professional Plus 2021 Using Outlook.com accounts in Outlook 16
T Outlook 2010 Cannot edit Calendar entries in OL 2010. Using Outlook 1
F how do i set a reminder in onenote 2010 Using Outlook 8
