Title and Suffix in Contacts
narvan21
Outlook 2013 64 bit
Hello everyone.
Is there any way to edit or add new items in suffix and title menus for example add the same words in other languages ? or delete some of them ? My outlook version is 2013.
thank you in advance.
You can type in / type over the entries in the fields but you can't add new entries to the list (to make them persistent) - you'll need to type them in every time.
A Outlook 365 Delete entries in title field, address book Using Outlook 0
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
V Can one change the formatting of email title blocks? Using Outlook 0
D Change senders title Using Outlook 1
C Why won't Title display in message list? Using Outlook 1
N Calendar Permissions - Delegates - View Title Only Using Outlook 2
A How to replace column title in address book Using Outlook 1
M How to change the Title of a form region at runtime? Outlook VBA and Custom Forms 3
M How to read color of form region title? Outlook VBA and Custom Forms 1
R Outlook with several IMAP accounts generating folders with 1111 suffix Using Outlook 0
L new outlook contacts searching Using Outlook 2
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
