Conditional formatting problem with "is not empty" and categories
schwarznavy
I made a conditional formatting rule to change the font on messages that have any Category assigned. I set the query as "Categories" and "is not empty." Guess what? It applies the formatting to every single message. I troubleshot the issue by unchecking every single other rule and it still does this. I also verified that the messages do not, in fact, have categories assigned and they don't.
Can anyone else confirm this behavior?
How can I apply a rule to any message that has a category assigned?
Another person had the same problem a couple of months ago. I couldn't repro it using their steps - they came back and said it only happened if show as conversation was enabled. I could repro it then. (I normally use show as conversation so its weird that i had it off.)
Rather than using is not empty, try using letters - if you use real words in category names, you can use just the vowels:
categories contains a,e,i,o,u,y
E Conditional formatting - when current account <> received account ? Using Outlook 3
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
S Conditional Formatting in calendar part of To-Do Bar Using Outlook 1
K Conditional Formatting based on Department of person received from? Outlook VBA and Custom Forms 4
C Change default colors for conditional formatting Using Outlook 2
D Conditional formatting - font sizes Using Outlook 3
A Help creating macro for conditional formatting settings Using Outlook 8
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
A Using OR when organising with conditional formatting Using Outlook 1
J Conditional Formatting Upon My Reply Using Outlook 1
N lose conditional formatting when importing to Outlook 2010 Using Outlook 2
T Conditional dates in Outlook Calendar Exchange Server Administration 1
R CALENDAR conditional formating not consistent??? Using Outlook 1
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
C View doesn't refresh (fields or formatting) Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
K Outlook tasks formatting Using Outlook 4
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
L Email to task without changin formatting Outlook VBA and Custom Forms 16
Diane Poremsky Use Word Macro to Apply Formatting to Email Using Outlook 0
D Outlook 2007 Formatting Using Outlook 1
D telephone formatting Contacts Using Outlook 2
A Lync meeting in outlook lose HTML formatting Using Outlook 3
Copwriter Paragraph formatting in blank messages/stationery Using Outlook 3
V Report stuck formatting page Using Outlook 1
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
J Formatting Contacts to Export for iPhone Using Outlook 0
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
G Outlook 2010 not formatting in-line comments Using Outlook 5
Commodore Auto-formatting of certain phone numbers Using Outlook 2
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
E Email Formatting - Tabs Using Outlook 1
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
H Formatting of email conversation print outs - URGENT Using Outlook 1
K Problems with message formatting for individual user Using Outlook 1
M Auto-correct Contact fields' formatting? Using Outlook 7
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
D Formatting Styles when Replying Using Outlook 10
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
