Any way to force sort by/group by on search results with VBA?
ajkessel
Outlook 2016 64 bit
Is there any VBA code that will take the current Outlook search results and apply a "sort" and/or "group by" on those results?
When search results span many folders, it takes several steps to add the "folder" field back into the results and then "group by" that field. Is there some way to automate it? It doesn't seem like "group by in folder" is "sticky" with pre-configured views.
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
O Force account selection for sending reply emails Using Outlook 1
C Force account selection - no reg path nor can create one Using Outlook 9
D How to force full message download for all Gmail messages in all folders with IMAP in Outlook 2013 Using Outlook 1
S Force Outlook to use TCP Using Outlook 1
C Defer email delivery - but when force sent using F9 Using Outlook 1
R Force use of general outbox Using Outlook 1
F force new meetings and appointments to send from my IMAP account Using Outlook 7
A How can I force Outlook 2003 to use A4 paper? Using Outlook 6
J Action based on number of emails after sort by from Using Outlook 3
Witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
King Mustard Sort search groups by amount of items? Using Outlook 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Diane Poremsky Sort messages by Sender domain Using Outlook 1
J Can I sort meeting requests by the date of meeting? Using Outlook 4
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
L Sort bar at top of inbox preview outlook 2013 Using Outlook 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
D Contacts Sort Order Using Outlook 0
kburrows Office 365 - Contacts Sort First, Last instead of Last, First. How to Reset? Using Outlook 4
I 2013 Calendar sort date Using Outlook 3
J outlook having sort by date or from unable to display sender name. Using Outlook 2
J Macro to periodically sort emails by flag status? Using Outlook 1
2 Sort taks by folder then by date? Using Outlook 5
S Outlook 2007 Sort Column Shading Using Outlook 1
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
D Sort e-mail by sender's domain - Outlook 2007 Using Outlook 2
B outlook sort by Using Outlook 2
A Sorting of existing contact in Outlook 2003 just will not sort Using Outlook 2
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
S changing number sort BCM (Business Contact Manager) 1
B Macro to Change sort and collapse groups in Mail folder Outlook VBA and Custom Forms 9
L Interating throught a task list, respecting sort rules in the view Outlook VBA and Custom Forms 1
A How to Sort by Unread and then Read mail in Outlook 2007 Using Outlook 7
S How do i sort email by Domain? Outlook VBA and Custom Forms 2
