bcm NOT installing
Becky Watkins
I purchased the standalone version of Outlook 2007 with Business Contact
Manager. The disc is only installing the regular version, without BCM. I
have tried repairing it, and uninstalling/reinstalling.
There is no Opportunities screen or the BCM toolbar. The only hint of it is
a bar on the left-hand side on the Contacts section that says Business
Contacts, but I can't even drag the contacts from My Contacts into there.
When I was testing it on the trial version of Office Professional (which i
uninstalled) it was working fine.
L
Luther Blissett
On May 18, 12:23 pm, Becky Watkins <Becky
Try creating a new Mail profile, run Outlook with the new instance,
and see if the BCM first use wizard comes up. If not, you'll need to
reinstall BCM.
R Installing BCM BCM (Business Contact Manager) 0
C Error installing BCM: requires outlook BCM (Business Contact Manager) 25
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
J Installing BCM 2010 on Server and Custom Form Layouts BCM (Business Contact Manager) 2
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
C Installing BCM 2007 on Remote Server with MS Server 2003 BCM (Business Contact Manager) 1
D Installing SQL Server 2008 Express with BCM installed BCM (Business Contact Manager) 3
A Installing BCM 2003 on Vista PC BCM (Business Contact Manager) 11
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
