BCM is 20 years behind times
denica
What is the point of BCM? Many features of Outlook doesn't work on BCM, like
Distribution Lists. Can you tell me how to move all my BCM contacts into
Outlook Contacts and then get rid of the BCM?
P
Pino
"denica" <denica> schreef in bericht
news:60253A30-81FC-4A88-A8E6-47DD7BC8973F@microsoft.com...
> like
drag - drop
denica
I would think there would be an easier "transfer" function or a "move"
function to get all of my 4600 contacts over instead of drag-drop but I guess
there isn't. I am still getting used to BCM's unruly relationship with
Outlook. It may never happen! Thanks for the suggestion.
> > like
> drag - drop
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
