BCM Not Able to Complete Task - Window won't Clear
SBE Linda
I get error message: This item cannot be saved with an attachment in the
comments area. Please delete attachment & try again. [I just started
getting this - I can't see an attachment. What is it asking me to delete??
the coffee guy
If you copied and pasted a picture or an image in the comments box under
details in the the history you will get this message. You can tell if you
click on what you pasted and there is a box around it. You will have to
delete the pictures and retype any information you need. Hope this helps
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
R Installing BCM BCM (Business Contact Manager) 0
