BCM without Exchange
Mapecsl
for our little office (5 Users) i'm planning to install BCM on a
Server. Is Microsoft Exchange required or will BCM run without it. Or
is it also possible to use an alternative such as Public Shared
Folders.
Mapecsl
baleine
It's not necessary to use Exchange, but it will be better.
I've the same configuration in my office (5 users). I have installed the
base only in one PC with XP pro SP3 who is in raid 1 and configure BCM for
all users.
All is ok.
Best regards
"Mapecsl" wrote:
> Hi,
> Folders.
> Thanks
> Mapecsl
dagr
is it possible to run BCm with Exchange without switcing between
profiles in Outlook?
Dag
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
O transfer BCM SQL data without backup BCM (Business Contact Manager) 1
N Can I install BCM client without SQL Express? BCM (Business Contact Manager) 1
