BCM not responding properly
bluebird
I can't backup or restore.. and the program is not linking my contacts. I'm
getting notification that it's in Single User Mode and is currently
connected. I am considering reinstalling. Is that the best course?
Raul Thomas
Were are you getting the notification ?
Regards
Rahul Thomas
MSFT
"bluebird" <redwood_sparks@earthlink.net> wrote in message
news:7F8A987B-9CAD-40BF-910A-BBBC27431BB2@microsoft.com...
> I'm
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
