Pop up information location issue
Gary D Hines
When trying to insert phone numbers in Outlook 2007, I'm asked to fill out the Information Location pop up. I've read to "configure" Outlook, but cannot "figure out" how to "configure outlook".
Is there a site, information available for someone like myself that isn't very savy in computer lingo?
thank you, Gary
For this you don't need to configure outlook - its a windows setting. You need to enter the area code in the Windows Control panel's phone and modem options. (It comes up in outlook so you don't need to go to the control panel, unless you need to make changes.)
WE have information at slipstick.com and outlook-tips.net for configuring outlook but if you have a profile, outlook is configured. It's just the area code that needs entered in windows.
thank you, Gary
Diane, I've tried that and when the country I'm calling from comes up, I can't get into that window to respond. Any ideas?
Thanks, Gary
If you can't configure it in outlook, go to the control panel, phone and modem options to set it up. Your country of residence should be listed by default in the dropdown unless you set up a different language in windows.
Windows has been set for English and the US. The window will not let me put any country in the drop down box.
V Yahoo via POP Using Outlook 5
B Trying to Merge Gmail and POP/SMTP inboxes Using Outlook 4
CWM330 I'm thinking about switching back to POP Using Outlook 11
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
P PST file is getting huge under POP 3 Using Outlook 2
O Get Outlook on your phone for free - web page pop up Using Outlook 8
J Change POP account to Forwarder - What happens in Outlook? Using Outlook 2
I Make a macro in line rather than pop out Outlook VBA and Custom Forms 0
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
CWM330 Infomational pop up Using Outlook 2
E POP vs IMAP on iDevices Using Outlook 3
J Why are emails for a different pop account copied to outlook.com account? Using Outlook 1
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Jennifer Murphy Exit Without Sending pop-up restarts countdown Using Outlook 11
V Switching from IMAP to POP Using Outlook 3
V Question on pop email Using Outlook 2
M Link POP account with Outlook.fr Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
C Outlook 2013 Windows Phone, Outlook 365/2013 POP Using Outlook.com accounts in Outlook 5
M Rule to pop a warning dialogue on certain actions Using Outlook 1
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
R Cant reinstall POP email account Using Outlook 2
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
S Pop up reminder while i close outlook Outlook VBA and Custom Forms 5
T Constantly Occuring Login Pop-Up Window Using Outlook 1
P POP mail password popup after I deleted the accopunt Using Outlook 6
L IMAP and POP email in same Outlook system Using Outlook 1
M Converting from POP to IMAP with Comcast Using Outlook 5
Sarge USMC Outlook 13 not displaying POP inbound emails Using Outlook 12
S Transferring POP emails from Outlook 2002 to Outlook.com email in Outlook 2013 Using Outlook.com accounts in Outlook 8
O Outlook 2013 EAS Account and POP Account - Common Sent Folder Using Outlook.com accounts in Outlook 21
S categories are being cut off after selecting from category pop up form Using Outlook 3
K EAS and POP folders in Outlook 2013 Using Outlook.com accounts in Outlook 4
A How to disable the pop-up “Reponses to this meeting will not be tallied." Using Outlook 0
O Multiple Exchnage profiles simultaneously and hovering pop-up contact card ! Using Outlook 17
P Changing from POP to IMAP; will this setup work? Using Outlook 1
D Imported Tasks - Pop Up does not work Using Outlook 3
B Outlook 11 for Mac - Imap or Pop Account Type Using Outlook 6
S Removing an Exchange Server account, retaining POP accounts Exchange Server Administration 1
S Converting outlook 2010 pop account and folders to imap with gmail Using Outlook 1
S No Pop Up Reminders in Outlook 2013 Using Outlook 1
L Download/export multiple POP accounts Using Outlook 1
