Multiple follow ups
benmosqueda
We would like to enter a number of follow ups when we set up a new client, how can I do that
Ben
As in Tasks due at various dates in the future? Is this in outlook or BCM?
In Outlook, there is no native way of doing this. You can use "natural language" dates to set up the tasks - for example, you'd type 3w for the date 3 weeks from today. See Time and Date Shortcuts for tips and tricks.
If there are a lot, you could use an Excel spread sheet to create the tasks and import. Excel formulas can skip weekends and holidays too. Once tge sheet is set up, you can enter the start date, save and import. The formulas set the other dates for you.
If BCM: I'm not sure. I don't think so, but I never looked into it.
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 3
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 3
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
J Multiple calendars Using Outlook 0
C Multiple emails Using Outlook 8
A Multiple signatures Using Outlook 2
L Multiple Inboxes Using Outlook 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
papa.deblanc Multiple Instances Using Outlook 6
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Multiple Outlook Invites Received by One Person Using Outlook 4
N Selecting multiple calendar items Using Outlook 4
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
N Multiple instances of Outlook on Start Menu Using Outlook 2
D Edit Subject (Multiple Accounts) Outlook VBA and Custom Forms 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
