Multiple Account Problems
fire_medic
I'm currently using an up to date version of Outlook 2010 and have been having some issues for the past several weeks. I have, properly, configured Exchange account and two IMAP accounts. The exchange account is only accessible when I'm at my firehouse, for security reasons, it is otherwise offline.
When trying to send e-mails from my IMAP accounts Outlook thinks I'm trying to send from the exchange account which promptly tells me that it is not connected. Each time this has happened I've checked the sending account and confirmed that it was one of the imap accounts. If I then try to save the e-mail its saved into the draft folder of the exchange account.
I'm sure you may need additional information, just let me know what you need and I'll be able to provide it. I've been using Outlook for a long time and thus am rather comfortable with it, but this problem has been causing me a lot of frustration.
Which account is set as default?
do you have SP1 installed? It fixes some issues with accounts, but this doesn't quite fit with the problems common in pre-Sp1 builds, so it may not help.
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
B Search Folder for search messages in more than one account and / or multiple PST folders Using Outlook 3
S Multiple Gmail account set up in Outlook 365 Using Outlook 1
Diane Poremsky Outlook, Multiple Accounts and the Default Account Using Outlook 4
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
C Multiple domains into one email account Using Outlook 1
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 3
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 3
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
J Multiple calendars Using Outlook 0
C Multiple emails Using Outlook 8
A Multiple signatures Using Outlook 2
L Multiple Inboxes Using Outlook 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
papa.deblanc Multiple Instances Using Outlook 6
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Multiple Outlook Invites Received by One Person Using Outlook 4
