Customization for BCM
wisehart
Outlook 2013 32 bit
I am not able to customize my fields in BCM for Outlook 2013. It's not an active option on the ribbon. I can see it, but cannot click on it. When I go to File--Business Contact Manager--Customize, Customize Record Types is also not active. I've tried customizing an existing contact AND a new contact. Any suggestions as to why I'm not able to customize?
W Ribbon XML customization Using Outlook 4
E Inbox field customization Using Outlook 1
E Outlook Ribbon Customization and Deployment Using Outlook 1
B Please help! Outlook, Exchange Server, and Customization BCM (Business Contact Manager) 2
B Please help! Outlook, Exchange Server, and Customization Exchange Server Administration 0
E Daily Task List customization Using Outlook 1
T Address book search customization Outlook VBA and Custom Forms 3
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
