BCM history will not display
  • Thread starter Thread starter Brent McDonald
Brent McDonald
I've encoutered the same problem. May I trouble you to expand a bit on what you mean when you say create a new Outlook Profile and configure BCM on it?
Thanks so much,
Brent
Posted as a reply to:
RE: Contact Manager History will not display
Hi Intellistructures,
Can you please create a new Outlook profile and configure BCM on it, and try
this scenario?
-Sat
"Intellistructures" wrote:
EggHeadCafe - Software Developer Portal of Choice
WCF Workflow Services Using External Data Exchange
http://www.eggheadcafe.com/tutorial...a-6dafb17b6d74/wcf-workflow-services-usi.aspx
I could not find a solution for this problem on the internet and stumbled across something that worked.
I decided I would create a new BCM database and then import my data. FORTUNATELY I did not have to complete that process.
Here is what worked. I clicked on the Tools tab and selected Account Settings. I clicked on remove and selected Business Contact Manager. I then Clicked Add and created a new BCM database and created a contact and make sure I could view the History. I then removed/disconnected from the new BCM Database and RECONNECTED to the old one with the intent to export the contacts. I figured I might as well try to view the history one more time before I went to the next and slightly scary step in this process and was DELIGHTED to discover that the Demon had been plaguing my database had been exercised. In summary I believe that if you remove/disconnect from your BCM data base and then reconnect to it you will enjoy success. I encourage you to make sure you create a full backup of your BCM data prior to attempting the above so you will be protected in the event that things don?t go as well for you as they did for me.
Cheers,
Brent
Thanks so much,
Brent
I have a slightly different problem. I had over 100 business contacts in MS
BCM running with phone log records attached. SQL data files were *.ldf and
*.mdf. They're backed up on an ext HD.
Then worst case scenario - my laptop HD crashed. In installed new, upgraded
to Windows7, and successfully intalled MS BCM. When I run the Contact
Manager Import Wizard it's only looking for *.bcm files, so it won't accept
any of my contact data.
What to do?
paul
> Cheers,
> Brent
> Thanks so much,
> Brent
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
J Unable to view History items in BCM 2007 shared database BCM (Business Contact Manager) 3
D Transfering BCM History BCM (Business Contact Manager) 2
J Outlook closes when accessing History in BCM BCM (Business Contact Manager) 4
N Moving communication history and activities from BCM to OUtlook BCM (Business Contact Manager) 2
M BCM History 'From' field not populating BCM (Business Contact Manager) 2
