BCM Offline
Dexter
Thanks in advance for your help. I have a user with a dell vostro NB who is
hooked in by an ethernet cable. BCM goes offline every once a while. Only
user it is happening to. 5 user BCM enviroment. He is not owner. Runnig SP 2
version of outlook 2007 BCM.
Dexter
Sun Embraser
On Feb 16, 9:38 am, Dexter <Dex...> wrote:
> Hi,
> Thanks
> Dexter
Hi Dexter,
If all other clients have no connectivity issue, then I can only
suggest checking the networking hardware on that Dell Vostro notebook
(or even try replacing with a different ethernet cable). Does the
notebook also experience on-and-off network connectivity issues with
other applications (such as IM, browser, file transfer utility, etc.)?
John
R BCM 2010 error creating offline copy of shared database BCM (Business Contact Manager) 1
E Offline BCM Problem BCM (Business Contact Manager) 1
M BCM 2007 Can not create Offline Database BCM (Business Contact Manager) 2
E Offline Billable Items from Business Contact Manager/BCM not Appea BCM (Business Contact Manager) 3
