BCM on Samsung i8000
  • Thread starter Thread starter Pesco
P
Pesco
Hello, because 'nobody can help me in italian discussion groups, I try in
English. Sorry for my English. I can not install the Business Contact Manager
on the Samsung i8000 mobile terminal. I tried to download the version for
smartphones and it says that the terminal is not compatible. Reading around
it seems that you need to download the version for pocket pc, but I did when
installing locks and me the following error "Setup Files Windows CE invalid.
Who can 'help me? Thanks
Is Samung i8000 running Windows Mobile 5.0, Windows Mobile 6.0, or
Windows Mobile 6.1? If so then this article may be of help:
<http://office.microsoft.com/en-us/outlook/HP011209791033.aspx
I don't think you can download the version for pocket PC because its
systems requirement is exactly like a proper PC/Laptop.:
"Supported Operating Systems: Windows Server 2003; Windows Vista;
Windows XP Service Pack 2"
I think you need to contact Samsung because they know what their Os is
loaded in their device.
Ciao.
THE INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY
KIND. LD55ZRA DISCLAIMS ALL WARRANTIES, EITHER EXPRESSED OR
IMPLIED, INCLUDING THE WARRANTIES OF MERCHANTABILITY AND
FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL LD55ZRA
OR ITS ASSOCIATES BE LIABLE FOR ANY DAMAGES WHATSOEVER
INCLUDING DIRECT, INDIRECT, INCIDENTAL, CONSEQUENTIAL, LOSS OF
BUSINESS PROFITS OR SPECIAL DAMAGES, EVEN IF LD55ZRA OR ITS
ASSOCIATES HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
DAMAGES. SOME STATES DO NOT ALLOW THE EXCLUSION OR
LIMITATION OF LIABILITY FOR CONSEQUENTIAL OR INCIDENTAL
DAMAGES SO THE FOREGOING LIMITATION MAY NOT APPLY.
Copyright LD55ZRA 2010.
In i8000 run Windows 6.5 and in the my laptop toshiba there is Vista.
I read that for terminal touch screen i have to download the pocketpc version.
tk
> Ciao.
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
