switching BCM between to computers
  • Thread starter Thread starter Joepie
Joepie
For Outlook you can switch Outlook.pst between two computers by keeping it on
a external harddisk or SD card. But what do I do with BCM to keep it
synchronised? I was not thinking about backing it up, but a more easy way? If
there is any
And thanks.
> there is any
> And thanks.
This discussion is closed and continued (if anyone reacts) in the
somewhat adjusted message Switching between computers. It is not
obvious how to adjust or delete messages.
CWM330 I'm thinking about switching back to POP Using Outlook 11
M Outlook 365 Switching from AOL to Yahoo automatically Using Outlook 5
V Switching from IMAP to POP Using Outlook 3
Diane Poremsky Help required for multiple identities when switching from POP to IMAP Using Outlook 1
A Switching folders in Outlook 2010 Using Outlook 2
M VSTO Outlook2007 Addin. After switching from 3.5 to 2.0 Framework i get "'MSB3185: EntryPoint not sp Outlook VBA and Custom Forms 1
