BCM at home
stepheng
Have you a method to update BCM away from the office? Is there an alternative to a VPN connection like http?
Forum Admin
No, its not sharable over the interent. (Many admins would not open the sql to the internet, even if it was possible to access it over the interent). If you use a laptop, you can take the database offline so you can use it from home (or anywhere). When you get back, you'll go online and sync changes back.
B bcm and "Office 365 Home Premium" 2013 BCM (Business Contact Manager) 1
B RE: Error: BCM Home Tab - Opportunity Funnel Chart issue? BCM (Business Contact Manager) 3
F Error Message when opening BCM Home and navigating to it BCM (Business Contact Manager) 5
