CALENDAR conditional formating not consistent???
rsisson
I have a real simple desire... When an appointment has a subject that contains "Appointment Information" I want it to format the Block RED.
EASY....so I thought...
It seems to work from today back about a week, and out about a week then the appointments show up as whtev they used to be...
I can get anything to work for TODAY, but I want to look at the MONTH view and be able to quickly spot all of those appointments...
I went to view, view settings, Conditional Formatting, Add (gave it a name, chose a color) clicked Condition, entered "Appointment Information" and "In Subject Field only" , OK, OK...
It formats TODAY and this week ok... but last week still has the old colors...
How do I get EVERY appointment that has "Appoinement Information" in the Subject to show up consistently....
I tried just Appoinement, Appointment (coma)Information... restarting after changes, and lots more...
HELP... I am missing something I am sure...but I have no idea what it is...
Are you using categories? When yoiu use categories, the category color overrides the conditional format color. The only way around it is to not use categories (as there is no 'no color' option).
S Conditional Formatting in calendar part of To-Do Bar Using Outlook 1
T Conditional dates in Outlook Calendar Exchange Server Administration 1
G Forms error on iCloud calendar Using Outlook 17
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
J Cannot edit a calendar event received as an invitation Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
L Synch Outlook 365 calendar with iPhone Using Outlook 0
C Recover calendar Using Outlook 0
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
L Duplicate calendar entries in Outlook 365 Using Outlook 3
G Stop Outlook 365 adding meetings to calendar Using Outlook 1
