Password, opening attachment problem
Amitava
Older version
I am using Outlook 2002 on a Windows 7 Ultimate platform. I have two queries:
1. My password is not being saved. Everytime I open Outlook I have to select Tools--Email accounts--View or change existing Email accounts--Change and then enter the password. Only then can I send or recieve emails. If I close Outlook I have to repeat the above steps once again as my password is not being stored.
2.Every time I open an attachment Outlook gives a message:
"What would you like to do with this file:
Open it
Save it to disk"
Even if I uncheck "always ask before opening this type of file" it still continues to do so the next time I open the same type of attachment. I want the default to be only to "open the file".
Please help.
Amitava
The password problem is a limitation of outlook 2002 on windows 7 or vista. See outlook on windows 7 for a utility that will help with the password.
What value do you have in the registry key at HHKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\AttachmentExecute\{0002DF01-0000-0000-C000-000000000046} ? That is the key that holds the open / save dialog 'don't ask again' preference.
Amitava
Older version
Thanks for the reply. The solution for the password problem is too complicated for a layman user like me. I guess i will live with entering the password every time i open Outlook.
In relation to my second problem I am unable to find Shel I|AttachmentExecute\....
When I oppen my Registry key using regedit I get HHKEY_CURRENT_USER\Software\Microsoft\Windows\Shel
Under Shel there are 3 options :
1. Assosiation
2. BagMRU
3. Bags
Nowhere do I find AttachmentExecute.
Please guide
Amitava
Amitava
Older version
I would like to bring the matter to your notice again. The registry path suggested by you does not seem to be correct. Pl help with the correct path. Sorry for all the trouble.
Amitava
Original Message:
1. Assosiation
2. BagMRU
3. Bags
Please guide
Amitava
My memory is fuzzy (heck I'm not even sure why I didn't mention this before)- but see http://www.slipstick.com/outlook/restore-or-hide-the-open-save-dialog/ - this is probably what you need, not the attachment execute key. Sorry for the wild goose chase. There is a 'do it for me' that will add the office document keys to your registry. I don't know if its UAC or Outlook 2002 compatibility issues that are causing your problem.
I opened a file in IE that brought up the save / open dialog and the key was set when i told it to always use my preference.
The key looks like this:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\AttachmentExecute\{0002DF01-0000-0000-C000-000000000046}]
"WinZip"=hex(0):
  • attachmentexecute.reg.txt
C How to fix outlook continuing to prompt fo an Exchange password Using Outlook 0
icacream New password won't update Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
T Outlook 2013 Possible interference by Telstra ISP with Hotmail Password Using Outlook.com accounts in Outlook 4
icacream Outlook 2016 “Enter your user name and password for the following server.” Using Outlook 5
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
M Microsoft 365 Outlook keeps requesting password on Local Account Using Outlook 1
icacream Enter your user name and password for the following server. Using Outlook 4
M Repeated password prompts Using Outlook 1
C Password not accepted Using Outlook 0
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Rupert Dragwater Outlook began asking for username and password Using Outlook 9
GregS Perpetual requests for password. Using Outlook 3
R Make Enter Network Password Prompt Go Away Automatically Using Outlook 0
R Outlook 2016 - How to change password in MS Exchange email client Using Outlook 0
Diane Poremsky Enter Network Password Dialog Keeps Popping Up Using Outlook 0
C Outlook 2016 asks for password Using Outlook 0
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
V Outlook 2016 occasionly asks for password again Using Outlook 1
R how to open a pdf file with a known password Outlook VBA and Custom Forms 1
Stompandgo Copied PST file asking for password - but I never created one?! Using Outlook 3
V Outlook 2013 keeps asking for password Using Outlook 2
A Offline folders password forgotten Using Outlook 2
P Constant Username Password Prompt Using Outlook 2
R Outlook 2013 asking for outlook data file password, there is no password Using Outlook 2
R Cannot Change password on host compter BCM (Business Contact Manager) 2
P POP mail password popup after I deleted the accopunt Using Outlook 6
D POP3 outlook not accepting my password Using Outlook 1
smokiibear windows security mail application not accepting username and password Using Outlook 0
G Enter Network Password box pops up every few seconds Using Outlook 2
C Password for backup of Outlook Using Outlook 1
D Outlook 2007 Repeatedly Requesting Password via Outlook Connector Using Outlook 1
K Outlook keeps prompting for Microsoft username and password for share calendar Using Outlook 0
B Outlook network password problem. Using Outlook 0
B Outlook 2010 asking for password constantly, won't accept correct one Using Outlook 5
G Outlook 2007 in Outlook 2010 asks for password Using Outlook 2
H Popup asks for password of an email account Using Outlook 1
N Prompt for password when sending an email Exchange Server Administration 1
T Outlook 2010 keeps asking password after upgrade Exchange Server Administration 1
L POP3 intermittently prompting for Password - Outlook 2010 Using Outlook 8
T Changed password now can't send/receive Using Outlook 1
K Wont send or recieve now with new server keeps asking for password when trying Using Outlook 1
