BCM not importing address
tdawnm828
I have repeatedly tried to import an excel 2007 data field to bcm 2007. Tried csv, xls. it does not populate the business street address even though it imports the rest city, state, zip. Trying to import this into BCM 2007. Any assistance would be appreciated. Not finding any help to resolve thru help available online or in BCM. Does any one else have this issue? Any help would be appreciated.
L Importing Opportunities in to BCM 2013 BCM (Business Contact Manager) 0
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
D Importing custom fields into custom form in BCM BCM (Business Contact Manager) 1
wallisellener BCM 2013 importing contacts from CSV file BCM (Business Contact Manager) 8
R importing excel spread sheet to bcm BCM (Business Contact Manager) 6
