Outlook 2007 Code for Note Fields of Appointment
Update in this area for macros I just asked about?
I read in another thread of this forum of a code that pastes to an appointment and with the fonts that come with it from a word document....I did and it is not pasting as the font of the document. I will show it below, and also just also need the macro to select all in the body field as if I did Ctrl +a and copy it all as if I did Ctrl + c. And here is the paste code I found that does not do it.Sub Paste_Un_FormattedClipboard()
Dim objItem As Object
Dim objInsp As outlook.Inspector
Dim objDoc As Word.Document
Dim objSel As Word.Selection
Set objItem = Application.ActiveInspector.currentItem
Set objInsp = objItem.GetInspector
objSel.PasteAndFormat (Word.wdFormatPlainText)
Set objItem = Nothing
Set objInsp = Nothing
Set objDoc = Nothing
Set objWord = Nothing
Set objSel = Nothing
Waiting to hear back from the Smart Woman!!!
Have not yet heard back from the Smart Woman!!!;)
Other than getting macros for selected and copying all words in the body field of the Calendar event, I have fixed it all so when I create the calendar event, select all, copy all, and run a word document, the word document puts the correct line spaces where I need them and fonts the words I want to font, and then it copies the word document within a few seconds....then just paste to the Outlook Calendar Event body it puts in how I want to see everything, as the "If"code I was given, works great. But when I decide to add to the Calendar Event body from the email field of the contact, just like we add the other field values, it will not recognize the email text and there is standard error.......so maybe any email is not text and here is the "If" code for the email field and what do we change so it will put in the email address: if item.getinspector.modifiedformpages("General").controls("Email").text <> "" then txtEmailAddress = "E-Mail Address" & ": " & vbcrlf & item.getinspector.modifiedformpages("General").controls("Email").text & vbcrlf
I just found the way to select all and copy all in the body field of the Calendar event....which is the macro below....but what can I change to select all and paste...as objSel.Paste does not work......and also, just need to know how to add the email as I said above....Still waiting for the Smart Woman!;)! Sub SelectAllAndCopy()
Set objDoc = Application.ActiveInspector.WordEditor
Set objSel = objDoc.Windows(1).Selection
objSel.WholeStory
objSel.Copy
This does it as I deleted the code lines:
Set objSel = Nothing So just need the way to add the email field
Sub SelectAllAndPaste()
objSel.WholeStory
objSel.Paste
So should the If line be: if item.getinspector.modifiedformpages("General").controls("email1address").text <> "" then txtEmailAddress = "E-Mail Address" & ": " & vbcrlf & item.getinspector.modifiedformpages("General").controls("email1address").text & vbcrlf
I did what I just wrote and it say it does not find a specific object
Any update to what the If line should be for purposes the email area? I tried based on your words, but not working....please let me know soon if you can.
Any possible update today to create the If line for email addresses? I need to add this as soon as possible
Update re the "If" line for the email please???
You'll be waiting awhile, only not so smart ones around here. :)
This is what you are still trying to get to work?
if item.getinspector.modifiedformpages("General").con trols("Email").text <> "" then txtEmailAddress = "E-Mail Address" & ": " & vbcrlf & item.getinspector.modifiedformpages("General").con trols("Email").text & vbcrlf
I took most of the weekend off. :) As an FYI, I'm going to be on a business trip and will only be working 3 days over the next 2 weeks, so I'm not sure if I'll have time to work on the problem.
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
S How to view backed up PSTs from Outlook 2007 in Outlook Classic's Folder pane Using Outlook 11
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
