Outlook 2007 Code for Note Fields of Appointment
itmAppt.Body = "Mobile Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone4").text & vbcrlf & "Business Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone1").text
try this
Dim txtMobile as string
if item.getinspector.modifiedformpages("General").con trols("Phone4").text <> "" then
txtmobile = "Mobile Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone4").text & vbcrlf
else
txtmobile = ""
end if
repeat for other fields then put them together in the body -
itmappt.body = txtMobile & txtbusiness
I did exactly what you posted and it does not add any words or phone numbers to the body when the contact has phone numbers
I'm sure the problem is in the if statement - i don't know if you need to use not = "
If Not Item.GetInspector.ModifiedFormPages("General").Controls("Phone4").Text = "" Then
or if you'll need to do it some other way with the controls.
If you comment out the if/end if lines, is something added to the body? This will test the string code and verify it is working.
thanks....don't understand the statement to comment out the if/end lines.....what should I do please?
And there is the error "expect end of statement, line 11" and line 11 is the Dim txtMobile as string
that is where you add an apostrophe to the beginning of the line so it doesn't work - it turns green
' if item.getinspector.modifiedformpages("General").con trols("Phone4").text <> "" then
' else
txtmobile = ""
' end if
if setting txtmobile to = the value and then adding to the body works, we know its the if statement that is not working.
As I repeat, I don't have this expertise, so what lines should i just take out as the ' in a script does not turn anything green. And what do I add as value to that other line? Thanks very much.
I did what you mentioned and had forgot to put the ' in front of the Else word....did it, and it shows the words and the phone numbers in the body......but when I don't have phone number, it still shows the words that I don't need to have in it
These are the code lines that we have added and each one has the first words and then the value from the specific conrol area......
So how can we adjust it so if there is not information in the value of the specifice control area, then I do not want the first words to show up on the body.
And secondly, how can we make all the words and values that show up in the body, as a different font and bold.....as I redid the form of the appointment, but it is not coming up as the different font and bold color.
Dim txtMobile
Dim txtBusiness
Dim txtlaststatus
txtMobile = "Mobile Number" & ": " & item.getinspector.modifiedformpages("General").controls("Phone4").text & vbcrlf
txtBusiness = "Business Number" & ": " & item.getinspector.modifiedformpages("General").controls("Phone1").text & vbcrlf
txtlaststatus = "Last Status" & ": " & item.getinspector.modifiedformpages("General").controls("ComboBox9").text & vbcrlf
itmappt.body = txtMobile & txtbusiness & txtlaststatus
Update for both questions tonight? Also, i there a macro that simple selects all words in the body field of the calendar event, and changes to the font to what I want...which would be Times New Roman, Bold, and 16 size and also, here is the code I recorded in Word to do it, but don't know how to change for Outlook....and of course, if the code in the script can create the font for the words that come from running the script that would be great.....
Sub Macro5()
' Macro5 Macro
Selection.WholeStory
Selection.Font.Bold = wdToggle
Selection.Font.Size = 16
This is to be expected when the if lines are commented out. I wanted to make sure the problem wasn't with that statement.
You need to use an if statement that skips the line if there is no value. I'm not sure why it wasn't working...
Do all of the numbers have a characters - like a dash or period - that will be present if the field contains a number? If so, you can look for that
if instr(1, txtmobile, "-") then
end if
if instr(1, txtbusines, "-") then
itmappt.body = itmappt.body & txtBusiness
end if
Do I add the if statements to the current codes which are the following or do I delete some of this and if they are not deledted, where do I put the if statements please?
txtMobile = "Mobile Number" & ": " & item.getinspector.modifiedformpages("General").con trols("Phone4").text & vbcrlf
txtBusiness = "Business Number" & ": " & item.getinspector.modifiedformpages("General").con trols("Phone1").text & vbcrlf
txtlaststatus = "Last Status" & ": " & item.getinspector.modifiedformpages("General").con trols("ComboBox9").text & vbcrlf
I put the following code that you gave me: if instr(1, txtmobile, "-") then
end if
and I put it under the line: txtMobile = "Mobile Number" & ": " & item.getinspector.modifiedformpages("General").con trols("Phone4").text & vbcrlf and when I run where there is not phone number, the words "Mobile Number" still show up in the body
In the past you gave me the code how I put words that a bold in an email.......so here is what you gave me before, and is there a way to this so my body words are bold?? Set objMsg = Application.CreateItem(olMailItem)
objMsg.HTMLBody = "<br /><p><b>Love You,<b> <br /><p><b>Dad</b></p><br />"
objMsg.To = oContact.Email1Address
objMsg.Subject = "From Dad"
objMsg.BodyFormat = olFormatHTML
MsgBody = objMsg.HTMLBody
The first line is showing up in the code as a color...do I change this first line? Public <span class="adtext" id="adtext_8">Sub</span> FormatSelectedText()
I did the following and it changes the font of the words I select in an email sending, but not the words I select in the body of a calendar appointment....so what do we change here and it will work perfectly..... Public Sub FormatSelectedText()
Dim objItem As Object
Dim objInsp As outlook.Inspector
' Add reference to Word library
' in VBA Editor, Tools, References
Dim objDoc As Word.Document
Dim objSel As Word.Selection
'Reference the current <span class="adtext" id="adtext_6">Outlook item</span
Set objItem = Application.ActiveInspector.currentItem
If Not objItem Is Nothing Then
If objItem.Class = olMail Then
Set objInsp = objItem.GetInspector
With objSel
' Formatting code goes here
.Font.Color = wdColorBlue
.Font.Size = 18
.Font.Bold = True
.Font.Italic = True
.Font.Name = "Arial"
Set objItem = Nothing
Set objWord = Nothing
Set objSel = Nothing
Set objInsp = Nothing
Just changed
If objItem.Class = olMail Then to If objItem.Class = olAppointment Then And it works!!! Thanks very much as usual!!! And just need what to change to the other code where there is not the value and don't want the words to show up
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
