Outlook 2007 Code for Note Fields of Appointment
Putting the if line aside, is there a macro that when I select or open a contact, it copies the email address of the contact, as I found another way to paste it in the calendar body but need a macro to copy the email address first?
Yes, that is easily done. The code sample at http://www.slipstick.com/developer/create-deferred-birthday-message-contact/ shows how to do it (and more) - basically, you need to identify the selected item and get the email1address field. if you want to copy the address to the clipboard, see http://www.slipstick.com/developer/code-samples/paste-clipboard-contents-vba/ - but you should use the field name if possible.
This quickie example creates an email message - you can create any outlook item. To use with open or selected item, use the getcurrentitem function, not ActiveExplorer.
Public Sub GetContact()
If TypeName(ActiveExplorer.Selection.Item(1)) = "ContactItem" Then
Set oContact = ActiveExplorer.Selection.Item(1)
Dim objMsg As MailItem
objMsg.body = oContact.Email1Address
'displays the message form so you can enter more text
objMsg.Display
Set objMsg = Nothing
Thanks very much but I don't understand.....I just need the simple code that copies the email address and does not paste it or do anything else with it as another part of what I have, will do the pasting....Can you just post the simple code please? Thanks so much!!
This is what reads the address - oContact.Email1Address - if your other code pastes from the clipboard, this won't work. It doesn't copy it, it only reads it. If you are going to paste it, you need code like this:
Sub CapturetoClipbaord()
Dim oContact As ContactItem
DataObj As MSForms.DataObject
Set oContact= ActiveExplorer().Selection.Item(1)
Set DataObj = New MSForms.DataObject
DataObj.SetText oContact.Email1Address
DataObj.PutInClipboard
- - - Updated - - -
Thanks so much....I tested it....there was an error...I took off one line as you will below and it works...as I copies the email addresss of the contact
Sub CopyEmailAddress()
'DataObj As MSForms.DataObject
Set oContact = ActiveExplorer().Selection.Item(1)
So what if line specifically for the email field please?
I have used the following code line with the words Email1Address and it says can find the object.....I have replaced with Email and E-mail and it does not work....same error. ifitem.getinspector.modifiedformpages("General").controls("Email1Address").text <> "" then txtEmailAddress = "E-Mail Address" & ": " & vbcrlf & item.getinspector.modifiedformpages("General").controls("Email1Address").text & vbcrlf
I added to the contact form, a new text field, which is TextBox29 and I copied to that text box in a contact, the email address of the contact, and used the If line you gave me to this TextBox29, and the txtEmailAddress equals the TextBox29, and then in the Calendar Event, the email shows up automatically as an email address. So, it might be that If line using the Email1Address does not work with the words .text so what can we change so it recognizes the Email1Address as an object...as the error is in can't find the object.
i noticed i looked at the code above earlier that you are looking for email1address - i don't think you can use controls to get defaults, only custom controls. That would explain why it didn't work...
It actually works for the other fields that I did not create....it works for FullName, Nickname, Company.....so these were not custom controls that I am aware of
S o can we change the If line to recognize the email field ? And if not, is there way to create a new text field that automaticaly fills in the text field the email address from the email field so it is a text field equal to the emai field?
Thank you. I did it and the error is "cannot find the specific object".....so again, what to change or also is there a way to create a text field that automatically has the words from the email field? And is what I tried again per what you said: if item.getinspector.modifiedformpages("General").controls("E-mail").text <> "" then txtEmailAddress = "E-Mail Address" & ": " & vbcrlf & item.getinspector.modifiedformpages("General").controls("E-mail").text & vbcrlf
i'm out of ideas. you could create a combination field that uses the email field - but i'm not sure that will work. See Step 5, down near the bottom for an example of what the field properties would look like.
I created combination field but it is not showing the email address in the contact
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
