Outlook 2013 Will Not Open!
Outlook 2013 64 bit
After I followed instructions on how to expand my mailbox size, I started getting a message that I "cannot rename system folders". I rebooted. Then Microsoft had some updates. Now I received a message stating that "the operation failed due to an installation problem. Restart Outlook and try again. If the problem persists reinstall". I restarted to no avail. But now, I can't open microsoft word or excel! Can anyone explain to me what is going on and what can be done? Seems to me that if I have to reinstall Outlook, I'll have to reinstall Microsoft office as well. If I thought that would solve all of the Outlook problems I would reinstall without hesitation. However, I'm just going to be back to where I was earlier today.
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
L Outlook 2013 won't open MS Office attachments Using Outlook 1
D Outlook 2013 Doesn't Send email from Web Page Unless Outlook Is Open Using Outlook 2
P Outlook 2013 search no longer works Using Outlook 2
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
