BCM must be activated
wallisellener
Outlook 2013 64 bit
Hello all
An user is always having troubles with BCM.
The problem is that after adding a couple of new contacts Outlook crashes and BCM must be reactivated.
Now this is becoming annoying because BCM must be activated each 4 days.
Please let me know if you have a solution.
Cheers
W
wallisellener
Outlook 2013 64 bit
This is really frustrating. I'm desperately searching for a solution.
There is one entry in the event viewer.
Name der fehlerhaften Anwendung: OUTLOOK.EXE, Version: 15.0.4420.1017, Zeitstempel: 0x506742d6
Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 6.1.7601.18229, Zeitstempel: 0x51fb1677
Ausnahmecode: 0xe0434f4d
Fehleroffset: 0x000000000000940d
ID des fehlerhaften Prozesses: 0x21b4
Startzeit der fehlerhaften Anwendung: 0x01cf588a1b4afac5
Pfad der fehlerhaften Anwendung: C:\Program Files\Microsoft Office\Office15\OUTLOOK.EXE
Pfad des fehlerhaften Moduls: C:\Windows\system32\KERNELBASE.dll
Berichtskennung: df48ec8f-c535-11e3-b076-f0def1d2d6be
System
Provider
[ Name]
Application Error
EventID
1000
[ Qualifiers]
0
Level
2
Task
100
Keywords
0x80000000000000
TimeCreated
[ SystemTime]
2014-04-16T07:08:13.000000000Z
EventRecordID
114939
Channel
Application
Computer
Security
EventData
OUTLOOK.EXE
15.0.4420.1017
506742d6
KERNELBASE.dll
6.1.7601.18229
51fb1677
e0434f4d
000000000000940d
21b4
01cf588a1b4afac5
Any ideas?
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
