Outlook Tasks Help
Eman1981
I have a user that says that they have Tasks in Outlook that are resetting to the previous day. The user will right click on them in the Task Pane in the bottom right of Outlook and select today and they will suddenly move back to yesterday. Sometimes it happens immediately, and sometimes it happens after about 30 seconds or so.
Does anybody know much about tasks and what could be causing this?
yes sorry as in the due date is changing. For example, the user right clicks Follow Up Tomorrow and the item pops right back up to the list for Today at the top. They are in cached mode on Exchange. I'm not sure if Syncing with a smartphone but probably. They receive the email on their phone but will that effect the tasks?
it depends on the phone. I'm thinking outlook thinks the task on another computer or device is the master because its newer. Double check the time / time zones - make sure everything is using the same time.
The user is using a Blackberry Z10. Do Tasks sync to BB?
I have an iphone with an exchange account and don't see my tasks.
The times and time zones are all the same. The user said they don't use tasks on their phone because they don't sync properly. They don't edit the tasks on their phone or anything.
J Is the Windows Outlook Tasks module really going to be gone? Using Outlook 10
B Outlook tasks and PDF Using Outlook 4
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
S Sync Outlook (2021) tasks with Microsoft To Do Using Outlook 1
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
peterbata Shared Tasks Outlook for Mac Using Outlook 5
K Outlook tasks formatting Using Outlook 4
T Extract Data From Outlook Tasks Using Outlook 0
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
S Editing Tasks in Outlook 2016 Using Outlook 6
A Outlook incompleted tasks has strike through Using Outlook 3
P Outlook search is not working at all for Calendar & Tasks Using Outlook 7
J outlook tasks on a phone Using Outlook 3
O VBA or other solution for Outlook tasks to OneNote Outlook VBA and Custom Forms 0
M Finding Tasks in Outlook 365 Using Outlook 1
K Outlook 2013 Tasks: Books Using Outlook 2
K Outlook 2013: Tasks versus Calendar Using Outlook 1
K GroupWise to Outlook 2013 conversion: Tasks Using Outlook 0
K Outlook 2013 Recurring Tasks Not Showing Complete Outlook.com Using Outlook.com accounts in Outlook 1
A Corrupt tasks in Outlook 2007 Using Outlook 1
O Tasks & Productivity in Outlook Using Outlook 1
Diane Poremsky How to use Outlook Tasks Using Outlook 2
J Outlook emails attached to tasks Using Outlook 4
T Outlook 2007 Export tasks to Excel Using Outlook 2
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
P Outlook 2013 Tasks - default view Using Outlook 1
V Deafault Task Folder --> Outlook.com tasks folder Using Outlook.com accounts in Outlook 3
Stefanos Update Sharepoint tasks through Outlook Using Outlook 2
L Outlook and OneNote Tasks Using Outlook 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
smokiibear follow-up flag fro Tasks in Outlook 2010 Using Outlook 5
K How to make use of outlook calendar, contacts & tasks using personal POP3 mail Using Outlook 1
L Outlook 2007 Update Fields Thru Tasks Using Outlook 57
M syncing Outlook 2013 tasks with android Using Outlook 2
H Cannot accept tasks from outlook 2013 or even from web Using Outlook 7
B Outlook contact, calendars, and tasks wont set up in icloud Using Outlook 4
P cant open tasks in outlook 2010 Using Outlook 0
