Outlook not syncing with iCloud
Vincenzo
Outlook 2021 64 bit
When I click the Refresh button in Outlook calendar, nothing is happening. Does not do the sync in either direction with the iPhone.
I've looked at the iCloud website, the new calendar events from Outlook are not there either.
I've uninstalled/reinstalled iCloud control panel. I've repaired the pst file. I've disabled all Outlook add-ins that are not Microsoft, except for iCloud add in. With Outlook shut down, I've gone into iCloud control panel and toggled the Calendar sync setting off, and back on.
Any ideas?
By the way, maybe I should mention that all of this started last week when my friend updated her iPhone with the latest IOS update. After the iPhone update the Refresh button disappeared in Outlook. Trying to reinstall the iCloud add in gave me the message "Your setup couldn't be started because of an unexpected error"
That is when I took all the steps listed above, which eventually restored the Refresh button, although it does not work. I thought is was worth mentioning this because I just read elsewhere in this forum a post from somebody else having the same issue, also as a result of the IOS update.
https://forums.slipstick.com/threads/92779-outlook-icloud/#post-339200
Please explain what you mean by "save directly in the iCloud calendar". Are you saying to create calendar events directly in the iCloud calendar? Or is this a one time thing when I am restoring the system, or is that the way it needs to be used on an ongoing basis?
The issue seems to have been cleared up by running antimalware scans with ADWCleaner and ESET online scanner. Seems odd, but that is all I did, and it has been fine since then.
VCC Icloud/Outlook Syncing Issues Using Outlook 1
V Syncing Outlook installs with iCloud Using Outlook 1
B iCloud and Outlook only syncing in one direction Using Outlook 1
C Outlook local calendar & iCloud calendar syncing query Using Outlook 3
K Syncing outlook with iCloud question Using Outlook 5
E Outlook and iPad syncing, IMAP and iCloud Using Outlook 11
R Outlook syncing with iCloud Using Outlook 1
M Syncing using iCloud mangled my Outlook 2007 file Using Outlook 2
P Syncing Outlook & iPhone Calendars Using Outlook 4
e_a_g_l_e_p_i Can someone explain syncing with Outlook and Gmail Using Outlook 3
F My hotmail calendar is not syncing with my outlook but my email is Using Outlook 3
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
C Syncing on outlook.com Using Outlook 4
H Syncing Outlook notes with ios Using Outlook 3
S Outlook User defined date field (UDF) not syncing Using Outlook 2
Diane Poremsky Syncing Outlook with an Android smartphone Using Outlook 0
R Outlook 2016 not syncing all folders Using Outlook 1
M Outlook 2016 - Mail Not Syncing With iPhone Outlook App Using Outlook 1
B Syncing Office 365 folders to match Outlook 2013 Using Outlook 3
J Outlook 2013 Syncing contacts with Android phone - Outlook.com vs Outlook apps Using Outlook.com accounts in Outlook 4
K Outlook 2007 IMAP account stops syncing new messages Using Outlook 0
K Outlook 2013 Outlook 2013 no longer syncing 1 of 5 IMAP accounts Using Outlook.com accounts in Outlook 0
G Outlook 2013 not syncing changes to outlook.com account calendar? Using Outlook.com accounts in Outlook 8
I Outlook Contacts and Calenders not syncing between PC, IPhone, and Windows 8.1 tablet Using Outlook 3
Commodore Syncing Outlook 2013 and Windows phone Using Outlook 8
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
B Outlook.com calendar no longer syncing with Blackberry Using Outlook.com accounts in Outlook 5
T Syncing iPhone w/Outlook Using Outlook 1
Marcy Outlook and SharePoint 2013 - Syncing Contacts Using Outlook 2
A outlook 2013 not syncing Using Outlook 1
D Outlook 2010 contacts syncing intermittently via Outlook Connector Using Outlook.com accounts in Outlook 2
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
P syncing outlook calendars Using Outlook 12
M Outlook and ipad syncing Using Outlook 1
S Syncing categories in Outlook for Mac 2011 with Exchange or Gmail Using Outlook 0
S Syncing Past events from Outlook 2013 to Outlook.com Using Outlook.com accounts in Outlook 6
H Syncing multiple types of Outlook accounts across various devices/systems. Using Outlook 3
M syncing Outlook 2013 tasks with android Using Outlook 2
L Outlook 2013 not syncing imap unless the "Inbox" folder is clicked on.. Using Outlook 2
I syncing outlook 2007 with live. com Using Outlook 4
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
