Too simple I would think but..
hutchen
New to outlook...I don't think i'm looking up the right 'lingo' for my question to be answered. When I view an email on my ipone 4s pop3 account, how can I make it so it is marked read in outlook and the reverse as well? Same goes with IMAP account??
D Can't read some emails - text size too small. Using Outlook 2
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
L Outlook saved template function too limited Using Outlook 2
D Too many scripts? Outlook VBA and Custom Forms 1
GregS Outlook 2016 Too Many Archives Using Outlook 0
C too many choices for time zones! can i reduce to actual time zones only? Using Outlook 1
M warning for too many appointments on a same day in Outlook Using Outlook 1
B Calendar shows too much info by default Using Outlook 0
M Charter ISP Claims Outlook Generating STMP Errors of Too Many Recipients Using Outlook 1
D Meeting Request - Too Many Recipients Using Outlook 0
Diane Poremsky "Too many files" Error Message Using Outlook 0
V Your Imap server wants to alert you to the following: Message too large Using Outlook 4
A Importing too many emails from Gmail Using Outlook 2
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
V IMAP: email is too large Using Outlook 1
mikecox Too many "contacts" lists Using Outlook 2
J Contact page too large for screen. Can't see categories, etc. Using Outlook 1
J Microsoft Outlook 2007 Font Size Too Small Using Outlook 1
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Font Size Too Small When Replying and Sendig Emails on Outlook 2007 Using Outlook 1
R Too Many Devices Using Outlook 2
G Opening messages takes too long Using Outlook 5
S too difficult of a question to google Using Outlook 2
E OWA phones home too much? Exchange Server Administration 1
S Using Scanpst too often? Using Outlook 2
R Too many folders in Outlook 2013 Using Outlook 11
D Navigate to my calendar. Too many steps Exchange Server Administration 2
J Contacts in 32bit 2010 filled with Bounce Emails (and contacts too)! Using Outlook 1
B Problem with fix for "Too Many Contact Folders" Using Outlook 3
D Font size too large on received emails in outlook 2010 Using Outlook 26
N error when copying outlook data "can not copy: the path too deep" Using Outlook 6
A Eseutil File Dump fails in the path to the file is too long... Exchange Server Administration 2
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
GregS Simple calendar sharing doesn't work Using Outlook 6
F Simple code to look for a specific line Outlook VBA and Custom Forms 2
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
L Simple Macro Using Outlook 1
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
F I want simple syncing between my 3 PCs and Android devices. Using Outlook 1
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
R Simple Sharing of Outlook Profile Using Outlook 1
