CPA - Office 2010 - 64 bit Questions
Kevin93940
OK, so CPA does NOT work with Office 2010 64 bit. Right?
But... It seems like I've seen a few posts where people have gotten it to work on their 64 bit machines?
Does anyone know if Microsoft is working on a 64 bit version?
My company has converted to 64 bit - so going back to 32 bit is not an option...
Thanks....
Correct, it is 32bit only. There is no way it read Outlook's calendar if using 64bit outlook. It will open and show a blank calendar though. I do not believe they are making a 64bit, not even sure if it will be updated for outlook 2013.
There is a word template that prints nice calendars -
Calendar Printing Tools - Slipstick Systems
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Using Outlook 11
M not all meetings are transfering to CPA Using Outlook 2
R CPA/Microsoft 2007 - Overlaid Calendars: printing workweek only Using Outlook 4
J Not all Outlook "My Calendars" show up in CPA Using Outlook 6
J Mod to Print Category Colors on Calendar Using CPA Using Outlook 36
C Which version of Office? Using Outlook 4
P newly installed Office 365 includes OLD Outlook Using Outlook 6
Y Q's Regarding Office 2019 Using Outlook 0
S Import PST to Office 365 Using Outlook 1
C Migrate Exchange to Office 365 Using Outlook 2
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
U Rolling Back Office broke automatic updates Using Outlook 4
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
S Outlook 2021 How to customize colors Outlook 2021 & Office 2021 on PC Using Outlook 1
O Office 365 - Zoom Using Outlook 0
C Wishlist Extract or scan new email addresses from out of office replies. Leads from OOO replies Using Outlook 1
M Upgrading from: MS Office Professional Plus 2010 to: MS Office Professional Plus 2021 Using Outlook.com accounts in Outlook 16
D Office 365 Outlook desktop app prompts for all account passwords on startup Using Outlook 11
V Outlook 2021 Microsoft Office Pro Plus 2021 - Inexpensive Lifetime License Using Outlook 6
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
klpconsulting Programmatic Access Office 365 Pro Plus & RDS Using Outlook 1
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S office 2016 pop3 Using Outlook.com accounts in Outlook 3
Albert McCann Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
