phone numbers fields in BCM are not correct
andyga
Hello
when I insert a new contact there are 4 fields for telefone numbers in the BCM form
there is "description of the field" then the "arrow to select" and then the "field for the number"
so when I see f.e. "pager" and I insert the number it is not "pager" but it is saved like "mobile"
and if I choose "pager" with the arrow, in the description field appears "mobile"
so the description does not match the result!
If Microsoft can only fix a limited number of field labels, which ones are the most important to correct?
Horsepower Contact phone numbers randomly change Using Outlook 0
wallisellener Contact Phone Numbers layout BCM (Business Contact Manager) 4
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
Commodore Auto-formatting of certain phone numbers Using Outlook 2
W Contact Forms Phone Numbers Outlook VBA and Custom Forms 1
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
P RE: Remove +1 and area code from phone numbers Using Outlook 5
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
M Gmail address associated with Outlook on new phone Using Outlook 9
P i-Phone 6s Plus receiving 2 notifications from Outlook email Using Outlook 1
D Duplicate Emails on Phone and Tablet Using Outlook 0
K Imap PC Outlook + Android phone Using Outlook 1
A new labeled phone field Using Outlook 4
I Outlook 2016 Outlook Requesting Phone Number??? Using Outlook 1
O Get Outlook on your phone for free - web page pop up Using Outlook 8
T Syncing to Android Phone Using Outlook.com accounts in Outlook 4
J outlook tasks on a phone Using Outlook 3
I Outlook on Windows Phone - compressed images .emz Using Outlook 0
Travis Lloyd Linking Outlook 2016 Desktop To POP3 Acc't On Android Phone Using Outlook.com accounts in Outlook 2
A added new calendar, now not syncing to windows phone Using Outlook 3
GregS No contacts sync from Outlook 2016 to Windows Phone Using Outlook 0
J Unwanted US Holiday Contact folder in Outlook.com syncs to MAPI/Phone Address book Using Outlook.com accounts in Outlook 9
M contact marked as completed in phone view but not when opened Using Outlook 2
iwshim softphone software for VoIP phone for OUTLOOK Using Outlook 0
J Outlook 2013 Syncing contacts with Android phone - Outlook.com vs Outlook apps Using Outlook.com accounts in Outlook 4
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
L Outlook 2007 Fix Phone Number Using Outlook 19
Glyn Outlook sync to Android Phone Using Outlook 1
P IM and Phone icon is Grayed out in Outlook 2013 - Using Lync 2013 Using Outlook 4
Commodore Syncing Outlook 2013 and Windows phone Using Outlook 8
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
mwh1962 Sync issues with Windows 8.1 phone Using Outlook 2
P Country name no longer shows in Phone number popup? Using Outlook 5
C Outlook 2013 Windows Phone, Outlook 365/2013 POP Using Outlook.com accounts in Outlook 5
B synching outlook 2010 with google on android phone Using Outlook 6
Binocular222 Get User Exchange phone extension Outlook VBA and Custom Forms 6
P Outlook 2013 Phone Number Format Using Outlook 0
D Journal problem recording correct phone number Using Outlook 7
A Updating Outlook Contact Phone Nos to international dialling codes Using Outlook 5
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
J phone icon greyed out in outlook 2013 Using Outlook 1
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
Terry Sullivan Android Phone E-Mails Not Disappearing After Being Deleted in Outlook 2013 Using Outlook 5
V Sync Outlook contacts and calendar to Android phone Using Outlook 3
