Proper setup to work with iCloud sync?
Ayzad
I apologize in advance for these questions, but I couldn't find their answers anywhere...
I have recently switched to a iPhone and I set up the iCloud Control Panel to sync it with my Win7 PC running Outlook 2010. I think I have solved most problems, but a few remain:
FIRST
SECOND
THIRD
How can I get Outlook to save locally an automatically updated copy of the data files? I mean, syncing in the cloud is nice, but I feel way more secure with a backup copy of my important stuff on my hard drive too...
Thank you for your help and patience!
1. The To-Do bar only shows the calendar in the default data file and the icloud can't be set as default. iTunes will sync over the local network and use the local pst file. It only syncs when the apple is on the same network as the computer though.
2. Do you want it default in outlook's contacts or in the address book? See http://www.slipstick.com/outlook/icloud-outlook-problems-syncing-contacts/#first to set it as the default address book. You'll need to use a macro to select it by default in the contacts pane. The macro on this page: http://www.slipstick.com/outlook/tasks/remove-todo-list-tasks-list-outlook/ can be tweaked to work with contacts.
3. The icloud is cached on the computer. Backing it up is somewhat pointless - icloud won't use it. Your Outlook pst file can be backed up - it should be in my documents\outlook files. You can copy it to make a backup when outlook is closed.
Diane, thank you for your kind help!
1) This is _really_ bad... Is there any workaround for this (like, in example, getting Outlook to automatically duplicate appointments from the icloud calendar in its default file, or something like that)?
2) Thanks!
3) My bad for phrasing it wrong. What I meant was:
- I am not aware of a file containing the same data sent to icloud on my pc. Should the icloud service not be accessible, I'd like to have the data on file too - but I understand that they are not saved in the pst anymore, are they?
- Is there any way to get my Outlook data saved on the pc too as I create/edit them?
Aw...
I did try to work the macro, but I couldn't make head nor tail of it... Can anybody help with the correct macro script?
Diane, you are an angel but I am starting to realize I am getting overwhelmed by the growing number of tools, plugins, scripts, idiosyncrasies and sheer lingo involved. Before diving in something that at the moment is way over my head, may I try another approach taking a few steps back?
My initial goal was "simply" to keep Outlook as it was while getting its contents (just the contacts and calendar appointments, really) synchronized with both an iphone and an ipad.
Given that we are talking about three of the most used IT products in the world here, I can't believe there is not any foolproof solution to get them working together... is it possible that I am approaching the problem the wrong way altogether?
D Check whether mail item is proper for sending or not Outlook VBA and Custom Forms 5
A How Do I Setup My Optonline.Net Email Account? Outlook VBA and Custom Forms 0
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
T Interim Outlook 365 Setup Using Outlook 2
Marc2019 Cannot setup Outlook Account on Mac Os 10.6.8 Using Outlook 3
Z Account setup on Android Using Outlook 3
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Q Mail account setup query Using Outlook 0
Laurent Duchastel New email setup dialog doesn't allow alias Using Outlook 2
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
C GoDaddy office 365 setup wizard erased old Outlook emails? Using Outlook 14
B New Outlook 2013 setup Using Outlook 8
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
C iCloud can't setup Outlook 2010 32bit Win 7 64 Using Outlook 11
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
J Want to 'modernise'(?) my email setup using Outlook. Any advice? Using Outlook 0
jChambler setup of iCloud with Outlook 2007 fails Using Outlook 4
D Setup of Outlook2013 insists on using OST for an IMAP account. Using Outlook 5
S iCloud Setup Using Outlook 4
P Changing from POP to IMAP; will this setup work? Using Outlook 1
V iCloud and Outlook 2007 iCloud - Initial setup with live data on all machines Using Outlook 2
V Outlook 2007/2010 - First time iCloud setup and config for heavy Outlook user Using Outlook 1
V Yahoo E-Mail Setup Using Outlook 2
J calendar print setup in outlook 2010 Using Outlook 1
G Outlook 2013, Windows 8 and Windows Phone 7.5 WP7.5 Setup Using Outlook 11
J How-to setup Outlook 2010, Windows 7-32bit, iPhone (so they work and play tog. Using Outlook 3
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
A can u setup o/l to autodelete 2g of email when it reaches 3g on a 4g mailbox? Using Outlook 7
C Outlook Shared Folder setup Exchange Server Administration 3
S How to setup a company calendar Using Outlook 3
C crash during account setup - can't delete corrupted account/data file Using Outlook 13
T More than one outlook account to setup & move Using Outlook 1
F BCM Setup Problem BCM (Business Contact Manager) 2
F How to setup signature with Outlook 2007 with external picture Using Outlook 4
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
