Multiple values for a field (like categories)
Dave M
Exchange Server 2007
The categories field(control) allows for multiple values (separated by a semi-colon). I was wondering if there are other fields that share this capability or is there another way to accomplish this.
What I am trying to do:
I have 5 custom fields on a form. Fields 1 and 2 are related and fields 3,4 and 5 are related. I would like to have a view that would display the records that contain information in fields 1 and/or 2, grouped by the contents of 1 and 2. I would like a separate view that would display the records that contain information in fields 3,4 and/or 5 and grouped by the contents of them.
I have successfully done it using the category field for all 5 fields and they show and group properly, but everything shows in one view. I would like to have 2 separate views and haven't had any luck using filters.
Thanks in advance for any assistance that you can provide.
Dave M.
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
J Multiple calendars Using Outlook 0
C Multiple emails Using Outlook 8
A Multiple signatures Using Outlook 2
L Multiple Inboxes Using Outlook 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
papa.deblanc Multiple Instances Using Outlook 6
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Multiple Outlook Invites Received by One Person Using Outlook 4
N Selecting multiple calendar items Using Outlook 4
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
N Multiple instances of Outlook on Start Menu Using Outlook 2
D Edit Subject (Multiple Accounts) Outlook VBA and Custom Forms 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
B Deleting multiple accounts Using Outlook 1
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
M Multiple spurious empty folders appear in archive files Using Outlook 3
