Imap read/unread problem
ricoh83
OS Version(s)
  1. Windows
Outlook 2019 64-bit
Outlook version:     2019
Email type or host:    IMAP
I know IMAP has been designed to sync with the server so if a particular mail is read on PC1, then it'll automatically
show as read without opening on PC2, PC3 so on and so forth which is what I don't want. I was looking for a solution, if available, and did manage to find two
links but its not working.
Any help would be highly appreciated.
There is no error message. There is a shared mailbox configured on 4 computers all with IMAP protocol and all running Outlook 2019(Desktop app).
The problem is when the mail is read on pc1, it automatically shows as read on pc2, pc3 even when that mail is not opened by the user on pc2, pc3 respectively. I've read about this and understand that that's how IMAP works.
What I am looking for is a workaround that when the mail is opened on pc1 it should show as unread on pc2, pc3 until the user opens that mail.
I found those workarounds as posted in the first message but those aren't explained thoroughly or maybe I am missing out on something.
Please help.
E Gmail folder -why, in .ost IMAP situation, as well as Googlemail folder? Using Outlook 0
S New Outlook - IMAP ISSUES and support for addins? Using Outlook 1
R Outlook with several IMAP accounts generating folders with 1111 suffix Using Outlook 0
N microsoft 365 IMAP Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
S Email was migrated from GoDaddy to Microsoft exchange. We lost IMAP ability Exchange Server Administration 1
CWM330 Discussion for all: IMAP + Safety Using Outlook 3
R Outlook 2019 accesses POP3 but says its offline (because of IMAP servers?) Using Outlook 0
B Strange MAPI/Exchange/IMAP behaviour in OL 2016 under10.0.19044.2006 Using Outlook 0
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
L IMAP Emails Disappear Using Outlook 0
V IMAP backup Using Outlook 0
K Imap PC Outlook + Android phone Using Outlook 1
V Scheduled backup of imap account Using Outlook 7
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
