Multiple Locations in Calendar not showing 2nd location in invite
ChrisTech
We have a user who schedules invites within Outlook 2007 to use two conference rooms within our Organization. When sending the invites, it won't show the 2nd conference room listed in the location line which can be confusing for the people its being sent to as they are in multiple locations.
The user is using Office 2007 with all current updates.
User's OS is Win XP Pro Sp3 with all current updates.
We are using Exchange 2003 and it should be patched to current date (I do not have access to this server - though I can have another group access this machine)
This has been an ongoing issue for this user for an unknown amount of time. I was recently made aware of it, so I'm not sure what has changed.
I've tried searching this site among others, with no real answer. That or I'm using the incorrect search terms.
Thanks for any input on this, its appreciated.
- Chris
She is the only one who is reporting the issue. Same issue happens when launching in safe mode.
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
J Multiple calendars Using Outlook 0
C Multiple emails Using Outlook 8
A Multiple signatures Using Outlook 2
L Multiple Inboxes Using Outlook 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
papa.deblanc Multiple Instances Using Outlook 6
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Multiple Outlook Invites Received by One Person Using Outlook 4
N Selecting multiple calendar items Using Outlook 4
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
N Multiple instances of Outlook on Start Menu Using Outlook 2
D Edit Subject (Multiple Accounts) Outlook VBA and Custom Forms 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
B Deleting multiple accounts Using Outlook 1
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
M Multiple spurious empty folders appear in archive files Using Outlook 3
