Folders not showing all contents
Sheila DuPell
I have 2 email accounts associated with Outlook. They are both POP3 accounts. The first one is fine. I am having an issue with the second one. I get incoming mail and file it in the appropriate folder. When I go back to open that folder, the recently filed emails do not appear. I then do a search for the email, and the search shows that it is filed in the appropriate folder. I can click and open it from the search, but when I go back to the folder, it still does not appear. I'm not sure what is going on!
Did you try resetting the view or changing the view on the folder?
D Desktop alerts not showing for folders other than inbox Exchange Server Administration 1
C Outlook on Mac & PC Folders not showing up Using Outlook 1
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
S How to get the actual Public Folder path from Favourites Folders Outlook VBA and Custom Forms 3
R Outlook with several IMAP accounts generating folders with 1111 suffix Using Outlook 0
icacream Outlook 2021 Win 10 - Nothing goes in my Drafts or Sent items folders ! Using Outlook 1
CWM330 Saving Data: Don't check certain folders Using Outlook 2
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
D This folder up to date vs all folders up to date Using Outlook 1
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
A Moving Public Folders to New Database Exchange Server Administration 3
Paul Hobbs Automatically accept "Empty Folders" prompt Outlook VBA and Custom Forms 6
D How To Combine Share Task Folders in just one Folder Using Outlook 0
Witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
vodkasoda Hiding empty Folders Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
R The way expand/collapse folders is actually meant to work? Using Outlook 2
