iCloud stops syncing again
Vincenzo
My friend's Windows 7 computer running Outlook 2010 with iCloud stopped being able to sync the calendar to the cloud. And the Refresh button was missing from the toolbar. This happened about 6 months ago too. At that time I reinstalled iCloud but iCloud was unable to start, gave an error that I did not record. I then repaired the Outlook file and that fixed it. (You assisted me in that repair, here is the link https://forums.slipstick.com/threads/91369-icloud-sync-stopped-working/#post-332542
So when it happened again today, I did the Outlook repair again. I probably should have checked the calendar at that point, but I went ahead and decided to uninstall iCloud. But it would not let me, said I needed to be an admin, which I was. So I repaired iCloud instead. Now everything is fine again.
Any ideas what caused this again, and what we might do to prevent it in the future?
iCloud can be fussy and I have no idea why it happened. I know Outlook 2013 will stop loading the icloud addin if Outlook thinks the addin takes to long to load (it's annoying, because its not the addins fault that it loads slow). Outlook 2010 will also do the same thing, but it's not as touchy as 2013.
Did you try signing out and back in to the iCloud? That fixes it some times.
Yes, I tried that, but it did not help.
When the Outlook repair tool finds errors, is that something to be concerned about, or are errors in the data file not all that uncommon?
G Forms error on iCloud calendar Using Outlook 17
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
B Outlook 2019 iCloud says “UN or PW is incorrect” but they are correct. Using Outlook 0
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
KeithJB iCloud calendar sync only works one way! Using Outlook 3
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
V iCloud Calendar invitations not sending Using Outlook 3
Horsepower Need iCloud mail only Using Outlook 1
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
M icloud removed my contacts Using Outlook 7
H Can't connect to icloud Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
